When coasting at high speeds, doubler makes gear noises---UPDATE W/ PICS---
Discussion in 'OffRoad Design' started by dawson444, Jun 23, 2004.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    Raleigh, NC
    Those are pictures of the shaft, what do ya'll think?
    I looked at the angles, they look ok, here are some pictures
    I have a doubler in my truck behind a TH400. When I am on the gas everything is fine, and when i am at low speeds I am fine. When I get up to high speeds (around 50-60MPH, my speedo doesn't work) and I let off the gas and I am coasting my doubler makes some bad noises in the gears. As soon as I start to accelerate again it goes away. What could this be? Thanks!
  2. Stephen
    Sep 15, 2000
    Carbondale Colorado
    Re: When coasting at high speeds, doubler makes bad gear noises, please help!
    The first thing I'd check is the rear driveshaft angles. We've solved these problems with the application of a CV driveshaft before so that's a good suspect.
    Do you get the noise in 4wd and 2wd? How about with the 205 in low or the 203 in low? I realize you may not get the same road speed in one of the low ranges but that would help troubleshoot where the sound is coming from.
    The fact that it's only at higher speeds and under coasting indicates to me that it could be driveshaft related. A minor vibration from the shaft would be damped out under power if the gears were all being pushed into mesh but when you're coasting they're not forced together and they could be rattling in the backlash clearance.
    Try some of this out and post up what you find, we'll keep working on it. If it gets critical, call up and we'll try to sort it out, that might work faster.
