when did the 208 stop and the 241 start.......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, May 19, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Are they interchangeable? Why is the 241 stronger anyway? I thought they are just about the same. thanks
  2. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    the last year for the 208 was 1988 and the 241 came in from 89-91 any year should be a direct swap and bolt in IIRC. I do know that the 90-91 model 241 had a different set up for the speedo and that the 89 still had the little plastic gears in it for the speedo. The 241 is a little stronger alum. case and has a lower gear ratio in it and also has an internal oil pump to help with lubrication. I also believe it has a slightly wider chain in it too.....Jason
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You can also get a SYE kit for the 241...
  4. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    Yeah I forgot about that don't know why cause I plan one for my 241....Taz
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks Damn my 90 has a 208 put in. Mike
  6. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    Some one must have replaced the 241 w/ a 208. I had a 208, it wheeled fine until I blew it up. Just enjoy it and plan what you want to replace it with in the future /forums/images/graemlins/thinking.gif when it is inoperable, or just takes a puke one day. /forums/images/graemlins/yikes.gif. You can keep your eyes open for a deal since your's is working. /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thats the plain. thanks
  8. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    depending on where you are 241's will be hard to find but good luck....Jason
  9. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Just got one! /forums/images/graemlins/waytogo.gif
