When do grinding discs wear out?
Discussion in 'The Garage' started by Pookster, Apr 19, 2007.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Im having a tough time figuring out when to replace grinding discs. Cutting wheels are easy, when they become a 1" nub, replace it. :haha:
    When do you replace grinding discs? I've been using the same one for 4 months... its gotten a bit slower to grind, but still grinds away... Is this supposed to become a nub too?
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    When it no longer "grinds". I have been using the same grinding disc on my angle grinder for about 8 years now. I got some awesome disc's from a friend that came from his work at an Auto manufacturing plant (NUMMI). :D
  3. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    I'm with Scott, I go until it don't go no mo...
  4. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    As with all things, I think the best approach is to look at the consequence of failure: if the disk were to shatter while rotating at high speed, pieces of disk could go in all directions, and really cause some damage. Given that, and the cost of a new disk, I only run them down to about 60 or 70% before replacing. I may be needlessly burning money in the name of safety, but Im willing to pay it.
  5. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    Unless you've dropped the grinder and fractured the disc it actually gets less likely to 'fly apart' as it wears down (less disc diameter, same grinder rpm = less speed at the cutting edge of the disc.)
    Rene
  6. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    ahh, so it DOES wear down. I was under this weird assumption that they dont actually wear away, but rather "dulls". I must just not be grinding enough.
    Any hints on how to clean up the metal spparks that fly everywhere?
  7. goldwing2000
    goldwing2000 Guest
    Vacuum cleaner or a magnet.
