When im all twistid up, ***solved*** *DELETED*
Discussion in 'Pacific Region' started by uglychevyZZ4, Jul 7, 2002.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Post deleted by uglychevy383
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Re: When im all twistid up, ............
    I'd guess that you have the mechanical clutch linkage...and it's probably putting a weird load on the fork when you get all twisty. The noise is probably the throw-out bearing complaining, I can't think of what else it could be.
    The real cure is to convert to a hydraulic clutch...no more bound up linkage headaches and no more leg cramps in traffic /forums/images/icons/grin.gif
    Rene
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    are the tires moving when it does it? my guess would be a bad tranny mount and when you are flexing it binds up the tranny by moving sideways or up /forums/images/icons/shocked.gif put a jack under the tranny and slightly lift up and see if it moves much it should move a small amount but not much
  4. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    new poly mounts, and not movin. is sittin still. im thinkin maybe the fork thingy?????????? /forums/images/icons/grin.gif
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Your linkage is binding. time for hydro. Or you could brace it.LOL run a front and rear engine plate to mount it solid to illimanate(spelled that wrong for sure,LOL) the flex,LMAO
  6. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    i didnt know there was a conv.. for the older stuff to hydro, gotta link or something telling about it? aka, p.n's or ???
  7. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    all you need to do is source a 86 and up chevy truck that had the 4 spd in it, grab the bellhousing, and clutch pedal and the lines. You also need the slave and master cyl.
    Also you will need to get a clutch that goes with the bellhousing.
    Do a search on the main forum, there has been plenty of post on it.
    chaz88k5 did one as did krazie87k5
  8. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Sounds like a T400 is in order /forums/images/icons/smirk.gif
  9. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Problem found.... after Doing much mudd chiseling and losing some of the Naches forest from underneath, I found a gap beetween the bellhousing and the tranny. got to looking further and found that both of the pass.. side bolts were sheared off in the housing /forums/images/icons/mad.gif so I guess I have something else to add to the list of things to do.
    I am however going to look for a T400 but it may be a while b4 i find one affordable, this broken vertabrae thing has put me down for a while.
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I solved mine too...hydro clutch /forums/images/icons/cool.gif /forums/images/icons/grin.gif
  11. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Was yours doin the same thing? I didnt believe it had to have that due to the fact it NEVER did it before as long as i have owned it. Im just dreading the job of dropping the tranny and removing the busted bolts.
  12. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    dude that sucks...
  13. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Has mine done it before...
    No it never did in the rig prior to me pulling it out. never has...and now...never will. /forums/images/icons/cool.gif/forums/images/icons/smirk.gif
  14. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    I just dont see any sense in doing the swap if its never done that, and will discontinue after i fix the broken bolts. besides, im lookin for a T400.
  15. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    One reason to do it is:
    Having a firewall that sits 6" farther back then stock,LOL
    2nd reason is to elimanate the bind when flexing.
  16. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    So how does the firwall get up and move backwards by going hydraulic? /forums/images/icons/shocked.gif /forums/images/icons/grin.gif
    Like I said, it dont matter because Im looking for a 400. /forums/images/icons/smirk.gif
  17. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    It moves back by going from a 1977 Blazer body to a 1955 Willy's Wagon. Same Wheelbase, just a different firewall placement.
    Looking for a Th400?? what case? need an Auto equiped Column???? Drivelines??
  18. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    what case? Drivelines??
    Uh, one that fits /forums/images/icons/grin.gif I dunno, Im not a tranny guy, just a everything else guy.
    and yes, I gotta get a column still.
  19. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    tilt or none tilt column??
    you'll need the case from the th400 too.
  20. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    I want a tilt, if i find one for a decent dollar. or even a indecent dollar /forums/images/icons/shocked.gif indecency is allways best /forums/images/icons/grin.gif and
    in reply to "youll need a th4oo case. ::::
    dont all t400 come in a case? /forums/images/icons/crazy.gif is there a difference beetween t and th---400? /forums/images/icons/crazy.gif
