when installing small black in s10...
Discussion in '1983-2005 S-Series models' started by bryguy00b, Apr 21, 2004.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    what do you do about the torq rods that bolt to the block? do u have to run those in the s10? i would think so..or will they have room enough to just bolt to the tranny
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    2wd dont use them. also they may not clear the cross member.
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    so then there just not needed then either? i was taking them of the engine after i had it out of the blazer, and it just poped into my head how i would use them when i go to put it in the s10
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep there no needed, they were only used on 4x4 trannys.
  5. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    if your talking about the rods that bolt to the side of the engine and run down to the tranny my 95 2wd has them but it's a 5 speed. maybe the auto's didn't have them.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i dont see the point of them and hoe they can help very much with anything especially with just one bolt at each end them them,
    my brothers 92 2wd s-10 pickup has these and its got 4.3L and 700r4 with aluminum K case style inspection cover
    if an engine and tranny flex apart form each otehr that much then something else is wrong that two little rods cant fix, IMHO
    good luck
