When is it time to replace my cat conv?
Discussion in 'The Garage' started by mtrdrms, Nov 24, 2005.
  1. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    The truck has 175000 on the original cat and I have heard that they get stuffed up and can decrease power. Is this true? Will I notice a difference in performance if I replace it or is this just heresay?
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    The only way to tell if the cat is plugged, is to drill a hole fore and aft of the cat and measure the pressure on each side, there should be under 1/4 pound difference between the two.
    To tell if is still working, bring engine up to operating temp (at least 180 degrees) then measure the tempurature for and aft of the converter, temp should be considerably hotter on the aft side (more than 100 degree difference) Hope this clears things up. :D
  3. mtrdrms
    Mar 14, 2005
    312
    Torrington, CT
    cool. thanks for the info. Ill try to figure out how to perform those tests.
  4. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    I don't think any factory cat will be actually working much after 100000 miles. Cats work by using a platinum compound to react with exhaust gases. At some point, there is none of the junk left to react with exhaust gases. If your state requires it, replace it... otherwise cut it out and throw it away.
    j
  5. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    When you can smell a rotten egg smell then you will know it's shot..
