when replacing the floor...
Discussion in 'The Garage' started by bryguy00b, Oct 6, 2002.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    befor i put the new rear floor in which side should i paint with por-15...the top side or the underside ...cuase the top side..on the inside of the truck i am going to rhino line the whole floor and the sides of the tub...and also when is the other half of that wright up on the floor replacment going to be finished..i tryed clicking and e-mailing the guy about it but it wouldnt work...
    thanx
  2. COLLISION
    COLLISION 1/2 ton status
    May 15, 2002
    175
    Kelowna,British Columbia
    I would not use POR15 on a new floor, the stuff is designed for rust or bare metal.Use a epoxy or 2k primer after you lightly scuff the surface, just make sure it's waterproof.
    After you weld it in it may also be a good idea to rust mist the whole underside including the channels that run across the floor underneath.
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    what is rust mist? a rust prevention spray or something?
    thanx
  4. COLLISION
    May 15, 2002
    175
    Yup, thats what it is.
    3M makes it in aerosol cans, called rust fighter
    Other companies also make similar products.
    Go to your local auto parts store and ask for wax oil, or rust fighter spray, they should be able to hook you up.
