when should an 700R change gears?
Discussion in '1992-Present Chevy & GMC models' started by enl, Jan 23, 2002.
  1. enl
    enl Newbie
    Jan 22, 2002
    At what rpm's on 5.7 should the 700R change from first to second, second to third and so on, when it is floored. It is on a 1992 2500.
  2. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    hehehee.............WOT from stop? my 4l60e wont shift outta first until around 3800 [​IMG]
    <font color=blue>Shorts</font color=blue>
    '94 K1500
  3. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    you have to adjust the cable to determint that... by the throttle linkage there is a cable that does down to your tranny, and there is a small D shapped place on the cable that you press a screw driver into. that will allow you to shorten or lenghten the slack in the cable until you feel comfortable with where it shifts.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    WOT they shift late.
    1-2 shift around 35-40mph
    2-3 shift around 65mph
    3-4 shift never if you leave your foot to the floor.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
