When switching from auto to manual...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Krase, Apr 3, 2003.
  1. Krase
    Krase Registered Member
    May 19, 2002
    90
    Northeast ,Tennessee
    When switching from auto to manual, from the 700r4 to sm465. On my 88tbi do i have to change anything with the computer setups or any other wiring issues?
  2. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    I did this swap when I installed a Tremec TKO in my Camaro.
    The only thing that I can think of that will be left over is the TCC wiring which goes to the tranny. You can let this hang, and you shouldnt have a problem. Also you might have to wire up your Park/Neutral switch so you can fire up the motor.
    Good luck
  3. dyeager535
    26,980
    Park/Neutral is the only real "killer" I can think of. Believe the only way you can get that corrected is with a different/new PROM setup for the 465.
    Auto trans vehicles know if the vehicle is in gear or not by you selecting gears on the column (start/neutral switch) and the manual trucks don't/can't of course.
    Park/neutral controls a fair amount of ECM activity in *cars* that vintage/equippage, but in trucks I can't comment with authority since GM did some weird things with the early TBI trucks apparently.
