when switching over to synthetic oils..
Discussion in 'The Garage' started by bryguy00b, Jan 2, 2004.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    is there anything you have to do? i thought i heard u cant just switch oils like that
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    thats a bunch of crap, oil is oil switch as you please.
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok..thats what i thought but i thought i heard that once bout mixin them or something with left over oil in there...just double checkin..
  4. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    that used to be the case, but not because it would do something bad to your engine, but the fact they could not recycle the oil when mixed. Obviously that changed since we now have synthetic blend.
  5. dyeager535
    26,982
    191
    What you may remember hearing is someone saying the vehicle leaked more after changing over to synthetic. Whether thats really true or not is probably open to debate.
    I think they now make engine oil "additive" that is for the seals (like they make for auto. trans) so as long as that was compatible with synthetic oil, that would be an option if you were worried about it.
  6. dyeager535
    26,982
    191
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    hmm nope never heard that..but now that u mention it ..i wonder cause my truck does leak quite a bit out the bottom of the pan..
  8. dyeager535
    26,982
    191
    Out the bottom of the pan, or just out of the bottom end?
    Those seal conditioners (thats what I assume those tranny fix products are) would work on the main seals and perhaps the pan gasket (if rubber) but just in case you really meant the bottom of the pan, there is supposed to be a seal that is used with the drain plug.
  9. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    ive heard that the reason they leak more after the switch is that conventional oils leave deposits in the engine and the synth's clean these away, however these deposits are what is left of seals pretty much, and when they go away, leak time.
  10. mr_fujisawa
    mr_fujisawa 1/2 ton status
    Sep 1, 2003
    288
    SF CA
    yah,
    i switched over to royal purple about 600 miles ago and haven't had any problems yet. i love the stuff and it's better for the environment too.
    /forums/images/graemlins/thumb.gif
  11. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I GUESS that could be true only because synthetic oil is sliperyer and could mabe get though the worn out seals and gaskets eaiser... ive also heard some time people have had slug /forums/images/graemlins/eek.gif free up when they switch to synthetic, but I dont have any experience with switching
    BTW that royal purple stuff is sposta be SWEET but REALLY expensive
  12. mr_fujisawa
    Sep 1, 2003
    288
    SF CA
    yeah, it is kind of expensive. . .but, nothing but the best for my baby!
    sean
  13. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea it leaks out the bottom of the pan, becuadse the pan itself is bad and rusted in some spots...were the PO had put some JB weld type stuff on the bottom..but it still seeps quite a bit.
    and whats so great about this royal purple stuff anyway? ive heard a lot about it..
  14. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    you cant just switch over to synthetic oils, they will free up sludge from the fossil oil and cause possible problems..ie plugged galleys etc..if you plan on swapping to synthetic, its best to do directly after the engine has been broken in on conventional oil...
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Eh...I don't believe that. Sure, it cleans your engine better than dino oil, but all oil has detergents. If any question, do a motor flush before installing synthetic.
  16. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I did it at about 90K miles and haven't had a problem.
  17. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    Quote:
    <<BTW that royal purple stuff is sposta be SWEET but REALLY expensive
    sean>>
    Hi Guys!
    What made you decide to go with Royal Purple, as opposed to a Mobil 1 or a dino?
    Tom /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Synthetic offers superior protection to dino.
    Mobil 1, while good oil, cannot be compared to more expensive synthetics.
  19. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Mobile 1 is damn good oil for the money. I just switched over to it in my 406.
  20. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    right now im running advanced auto 10w-40!! nutin but the best fur my baby!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/peace.gif
