when the wheather changes, does your truck do anything wierd?
Discussion in 'The Garage' started by colbystephens, Nov 8, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    when it gets cold my manual window cranks get really hard to turn the first turn (only). when it starts raining, my keys don't work as smoothly in the locks. :o
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    My passenger side window motor works really slowly, and back a few years back when i lived up in Flagstaff, the truck would start up in the very cold morning, but imediately die out, hit the key again and would be fine from then,,,never did figure out what the heck that was all about.
    Oh and i also needed to drop out the 20w-50 oil that was in it from Phoenix, did alittle slow cranking when really cold...:p:
  3. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    in the cold my keys start to work better...I dunno
    and yeah my windows have a harder time going up and down...my driver's side is acting more strange than usual lately...the passenger side is always slow but it never has any problems....go figure.
    -Avery
  4. jfabert
    jfabert 1/2 ton status Premium Member
    Dec 1, 2004
    161
    South Ogden, Utah
    I just get new noises. I have a pully that squeeks and the body mounts creak alot. When it rains or I wash the truck (most of the time its the same thing) the drivers front leaf pack pops when compressed.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    when it snows the big red front bumper on mine drags the ground. :haha:
  6. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    funny thing
    when it rains mine gets wet:haha: and when it snows sometimes my door locks won't turn and in the summer for some reason the seats get really hot, like i left the seat heater on and the funny thing , i don't even have heated seats.jk/jk meant in good fun:haha:
    seriouly tho when it gets cold my power windows roll down a little slower...i 1st thought it was the cold weather working on the battery but it turns the motor fine and its a yellow top optima. i think the grease on the windows mechanism may be cold and hard and slowing them down, because they roll down slow even when its running and i know the battery is hot.:dunno:
  7. babyburb
    babyburb 1/2 ton status
    Oct 24, 2006
    2,344
    1H North of Dallas
    My power tailgate window in the burb gets hard to hardwire with gloves on. Dadgum thing doesn't want to ground itself! Why make the inside of a key cylinder plastic?
  8. jdemaris
    jdemaris Registered Member
    Apr 10, 2001
    76
    Cold weather
    My problems apply to several vehicles - not just Chevys. When the temp gets below 20 degrees F - my wife's Volkswagen diesel Jetta's horn beeps when starting it. That's a weird one. My 86 S15 Jimmy speedometer squauks and the needle bounces all over the place until I drive for awhile. At zero degrees - my 85 Ford F250 diesel will have no brake booster function - it seems to freeze. Ford uses a vacuum servo instead of hydro like GM. Once the truck runs for 15 minutes and gets some heat, the booster frees up. At 20 below or colder - my 95 Subuaru AWD Impreza goes nuts when you first start it. Check engine light, gauges, AT overheat light, etc. All goes away after 5 or 10 minutes. Oddly enough - all my 80s vintage Chevy diesel trucks work fine at lower temps - if you can get them started - except the K5 Blazer rear windows will never open when that cold. One more - I had to start my 85 Toyota truck one morning when it was 35 below zero. To my surprise - it started with no block heater etc. - but firt the key-switch would barely turn and got stuck in the start position, the seat-vinyl cracked when I sat on it, the manual gear-shift would not move, and . . . when I turned on the radio - the power-button broke off. When I finally got rolling - it felt as if none of the shocks were working at all. After a few miles, things smoothed out.
  9. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,924
    336
    Fort McMurray, Alberta
    When it gets to -40, my trucks have to work really hard to get moving cause the diff and tranny gear lubs get thick at those kind of temps. Shocks don't work either, so its an extremely stiff ride.
    Also, when you first fire them up at those temps, the engines knock something horrible for 5 - 10 seconds until they manage to squeeze the ketchup like oil through the venturis, lol My K25 has a TPI setup, and I installed a fuel pump relay bypass switch, so it will not turn the fuel pump on until the engine has built up oil pressure. Means I gotta crank the engine a bunch, but its much easier on my bearings, and having a 1500 CCA battery, its no big deal.
  10. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    When I had doors and a tailgate, The windows would not work at all in the winter. The motor knocks for about 3 minutes.
  11. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    whenever I had power windows they would work a lot slower in the cold. swapped out for manual though. also my holley carb is chokeless so its kinda hard to start when its cold but Ive got a new q-jet that Im gonna put on soon.
  12. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    :yikes: !!!
  13. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    when it rains (and i have my doors on) the windows go down alot easier... when it gets really cold (32 or so) up in the mountains, my windshield wipers dont like to work to well.. oh and its a diesel so they dont like being snowed on at 10k feet and starting in the morning. lol..
  14. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    slap-happy
    I had a few motors that had slappy pistons once the temps dropped below 30 degrees--they start "clacking" at idle right after starting,and continue to make noises until they warmed up--then quiet as a mouse again..GM claims they are "barrell ground" and may be noisy until the engine reaches operating temparature..
    I've had starter drives that refuse to turn the engine after a frosty night too,had to use a propane torch to get the dam starter thawed out,and get it started!..had to replace the starter drives..
    Then there is the heater blower motor that runs normal upon a cold start,then suddenly starts shreiking like a cat with its tail in a blender,or makes a bad rapping noise!--scaring the living crap out of ya!..:doah: Every time my truck does that,I start seeing pictures of a block with holes in its side in my mind!..:eek1:
  15. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    On my 76 GMC the window wipers don't work when it gets down to freezing. Work fine the rest of the time. My 71 Blazer is so gutted, nothing works and nothing changes.
  16. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    My 82 Jimmy's "Fuel in water" light turns on whenever it drops below 45 deg. :confused:
  17. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,008
    609
    Pueblo, CO
    Mine does that too! I usually change the fan speed to make it go away. Once it warms up it won't scream at me. It sure is an eye opener :eek1: though.
    Mine's a little slower to crank when below freezing, but it will start every time. It's the only time I wish I was using the stock air filter housing for the heat stove from the manifolds.
    Leaks from the door window seals when raining (full convert 75). I do like the side effect from snow bashing though. Makes the truck almost as quiet as a lexus inside. Well a lexus with wind noise from the rotton door seals! Just no more pop's squeaks and creaks...
  18. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    im really glad it doesn't get near as cold here as it does as some of these places. i dont really have any issues in the tx winters.
  19. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Are you kidding!!!!!! It is almost down to 60 degrees here and I don't have a heater. I'm thinking about parking it until March when the temps will be a more reasonable 110 degrees.
  20. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Pansy...:wink1: I don't have a heater and I dd my rig....its been in the 40's most mornings around here.
    -Avery
