When there was a K
Discussion in 'The Garage' started by 1BEATK5, Aug 21, 2006.
  1. 1BEATK5
    1BEATK5 1/2 ton status Premium Member
    Dec 15, 2005
    2,735
    32
    beaverton orygun
    Does anybody remember what years the hd. K case th350 was made? I broke mine in half by the modulator, and am looking for a replacement and in my neck of the woods it's pretty easy to find a whole parts truck for pretty cheap. I found a k10 with a 350/205 minus motor for $350, but it's 60 miles from me and my d.d. only gets 8mpg. 2800rpm at 60.:doah: thanks in advance.
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I am not a 100% on this but I belive they started in late 1978 and went through 1981 .
    Tom
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    My understanding was that all trucks had a K case as it has the thicker flange where the ally torque converter cover bolts up.
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    TH350? Are you talking about the 700R4?
  5. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    That's my understanding also, I'll try and confirm.
  6. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    My info states that the 4x4 th350 was offered on Blazer/Jimmys from 1970 thru 1979. On trucks depending on a number of factors, it was offered 1969 thru 1979.
    Hope that helps.
  7. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    TH350's were offered up to 1981/1982 and there were no "K" cases before 1978 . Most ( if not all ) "K" case TH350's will be of the lock-up converter style that were built in 1981 and later.
    HTH's Tom
  8. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    Tom, are the 4x4 350 trannys not "K" simply because they are 4x4? Is there a "hd" 4x 350 just in the years you mention? I have no info on this.
    Edit: maybe because I was only considering the non- lockup type.
  9. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    I might not have been clear - sorry . I was refering to the "K" case as an "HD" case . Just to clarify - to the best of my knowledge all TH350's built after sometime in 1978 ,that were installed in 4x4's, were "HD" cases.
    Tom
  10. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    Not sure my self, but it makes sense that the General would have beefed them up, I've seen plenty of broken ones.
  11. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Those strut bars bolted to the dust cover were a great idea ! GM did a fine job on that one .
