When was the NP241 introduced ?
Discussion in 'The Garage' started by Executioner, Jun 15, 2005.
  1. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Lets talk about the NP241 when did it first show up ?
    When on Blazers ?
    Does it mount up like a NP208 ?
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    89' and it mounts up the same as a 208.
    It has a oil pump rather then oil slingers like a 208 and the chain is a bit bigger on the 241.
    Also has a bit lower gear then a 208.
  3. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Well, that about covers it.. :D 'cept maybe for the fact that, it too, is an aluminum case, like the 208.
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    It can also be made fixed Yoke with over the counter parts. :thumb:
  5. Executioner
    Feb 22, 2000
    1,530
    Anyone whatching price and avalability ?
  6. icer97
    icer97 1/2 ton status
    Jun 15, 2005
    116
    Missouri
    The IFS truck 241 have a driverside drop.
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Most go in the $100-$200 range. If you are trying to put one in a 88' or older you can only use a 241 from the 89' year model since they are the only ones with the mechanical speedo where as the 90's have the electric.
  8. dyeager535
    26,979
    Nah, that just means you convert to '90-91 electric speedo. Who wants a speedometer cable?? :)
