When you clocked your 205 flat
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stomper, Jan 1, 2004.
  1. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    did you get some side to side angle, like the 205 output is off the center line of the front axle pinion? Just seeing if what I have is normal since the output would be rotated in a radius. If that makes sence /forums/images/graemlins/tongue.gif Thanks,
    Brett
  2. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    You might PM Mudzer.
    He runs an inverted 203 and a 205 clocked flat.
  3. Stomper
    May 11, 2002
    3,767
    Iowa
  4. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    As theBigdaddyof2 said, Mine is clocked flat. There is more of an angle [side to side] than before, but not enough to give me too many problems. My major issue was in the angle going down to the yoke on my 60. It is a little severe, in fact I still have the junk Saginaw CV up front and it has been majorly modified to have more droop. Still, when I am wheeling at speed in the snow, it makes a bunch of noise. Since I haven't won that High Angle Driveline yet, I decided I am building my own CV shaft with sufficient angle for our applications. You take a 1310 CV shaft and disassemble the CV. Discard the center pivot and the Center "H Casting". Purchase a 1330 Center "H casting" and center pivot as well as 1310 to 1330 conversion u-joints. With some slight clearancing you can have a shaft that will operate at a fairly good angle. I then re-tubed the shaft for the length I needed.
    I'll crawl under mine this weekend and snap some pics of the shaft angles.
