When you shim your axle...........
Discussion in 'The Garage' started by stallion85, Jun 18, 2005.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Do I need to buy a new spring pin that will go all the way through the shim and into the spring perch?
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    From my experiance,if you have aftermarket springs the spring pins are long enough to go through the shim and into the perch.If not,new pins are cheap enough :D
  3. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Word, thanks for the info :)
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Oh ya, if I recall when I put the 14ff on I had to trim the pins down to get the springs to sit flush on the perch.
    If the pins did not go all the way through, what would happen? Could the axle move around even if the u bolts were torqued down properly??
  5. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    No problem :thumb: Just make sure the pin makes it into the perch :D
  6. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Yes it could.
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Thanks Frizzle :grin:
