Where are the casting number on a 1972 engine block?
Discussion in 'The Garage' started by 72Blazerod, Jan 10, 2003.
  1. 72Blazerod
    72Blazerod 1/2 ton status
    May 18, 2000
    264
    Vancouver, British Columbia, Canada
    Hi guys,
    I have the a 350/350 set up out of a 1972 GMC 3/4 2wd truck at my place and I may have a potential buyer for it but he wants me to check out the casting numbers (I believe) to tell what type of block it is. He showed me a picture of the numbers on a stripped engine and it looked to me that they were cast right into the block and not stamped. The last three numbers were the important ones and they were 010. Can anyone tell me where on my engine I should look for these numbers to see if I have the correct engine for this guy? Any help is appreciated!!
    Thanks,
    Rod /forums/images/graemlins/1zhelp.gif
  2. motorheadnelson
    motorheadnelson Registered Member
    Aug 12, 2001
    80
    Fort Mohave AZ
    What's he looking for? The casting number on a 010 block can be found behind the left cylinder head on the flywheel housing. 3970010 is the number. These blocks were used as 69 302 DZ 4 bolts, 69 327 truck and industrial 2 bolts, and 69-80 2 and 4 bolt main truck and passenger blocks. For actual application and hp rating you need the stamped number on the pad in front of the right cylinder head. I have a 69 010 300hp 350 four bolt in the garage. If you need more info, maybe I can help.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    And theres always this place:
    Mortec
  4. 72Blazerod
    May 18, 2000
    264
    Great, I'll go down to the garage and take a look, I knew one of you guys would know this. Thanks for the helping hand!!! /forums/images/graemlins/thumb.gif
    Rod /forums/images/graemlins/k5.gif
  5. 72Blazerod
    May 18, 2000
    264
    I found the number. It was 3956618. Was this a good engine? Do you know what the difference is between this and the 3970010 engine? Does this sound like the stock engine for a '72 GMC pickup? Thanks again for the info.
    Rod /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  6. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Well, with that number, it could be a 1969 302,327,or 350, and it could be a 2 or 4 bolt main. so really you cant tell unless you yank the pan and get a casting # from the crank and count the main bolts.oh well, it was worth a shot /forums/images/graemlins/crazy.gif
  7. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Both options are 4 bolt mains. Just pray you've got the '69 302 /forums/images/graemlins/wink.gif
    1969 3956618 302-290hp - 4bolt main- Z28
    1969-79 3956618 350-165hp 350 4 bolt main- car, truck, vette
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    It could be the stock engine. Chances are its a standard 350.
