where are the fuel fitlers on TBI???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Jul 23, 2001.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    OK, I changed the filter on the frame in my K5 (89 TBI) and I am wondering if that is the only fuel filter it has??? help would be appreciated.
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  2. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    only one i know of
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  3. Bowtied
    Bowtied Registered Member
    May 21, 2001
    69
    NC
    Solowookie,
    I have an 87 and a while ago I went over all the lines from the tank to the TBI looking for a fuel leak and the only filter on mine is the one on the frame rail passanger side.
    Hope that helps,
    Andy (Bowtied)
  4. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    That is the only one except for the pick-up screen on the tank mounted pump.
    '85 K5 : Run it til it breaks, then fix it and go again!
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The one on the frame is the only one on the fuel lines.
    There is also a filter on each injector. You have to remove the injector from the fuel meter body to get to it.
    In the gas tank there is a strainer on the fuel pick up that stops particles big enough to damage the pump. If it gets twisted or damaged( this can happen when siphoning gas) it can restrict fuel flow. Blowing air back thorugh the fuel line can sometimes unclog it.
    These are all the stock filters on a TBI system that I know of.
    <font color=orange> You are just jealous, because the voices only talk to me.</font color=orange>
  6. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    hey guys thanks a ton for the info. I put some Lucas in so when I get through this tank of gas it should clean out the injectors if there is a problems.
    when I added Lucas in my Grand Prix in had 40,000 miles on it. it ran good, but gas milage was horrible. I gained back 3 MPG with this stuff! (awesome stuff)
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Lucas? What's this miracle stuff?
    The only Lucas I've heard of before was the Prince Of Darkness British electrical company. [​IMG]
  8. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Lucus is awsome! They make it as a fuel additive, tranny additive...just about anything I believe and it's all good! I think they make some to go in the diff and standard trannies.
    I've got a mind like a . . . a . . . what's that thing called?
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer/>http://www.geocities.com/muddin4fun79blazer/</a>
  9. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    the stuff that goes in the diff and trannies (manual) is the same stuff that goes in the engine. you just put it in with differenct percentages.
