Where are the good Phx AZ Drive Shafts Shops??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87GMCJimmy, Jan 7, 2002.
  1. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    I'm in need of a drive shaft shop to rebuild my front shaft. Just wondering if any Arizonans had experiece with any of the local shops.
    Mike
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    A couple of years ago when I installed the Doubler, I spent a lot of $$ on driveshafts at 2 different shops.
    Driveline of Phoenix (I think that's the name) on Washington street made the rear CV shaft to my custom specs. Great shaft and excellent work.... but pricey!
    I did the front with Az Driveline (Gloeco) because at the time he was the only one who was making the 11" long slip yoke "Rockcrawler" shafts. This shaft has held up, but the workmanship is inferior to the rear.
    I've also had good and affordable work done at Dick's Driveline.
    Marv
  3. 87GMCJimmy
    Nov 21, 2001
    582
    Phoenix, AZ
    Thanks,
    If I need a new slip yoke is it worth it to get a longer one? When I pulled my drive shaft apart the slip yoke loosed up quite a bit after I cleaned out the petrified grease. The grease had dried out and comacted so much that at first I thought it was some kind of rubber/felt seal.
  4. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Also try "Dick's driveshafts" here in Phx......2750 E. McDowell Rd.
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Mesa Driveshaft, only if you know someone there though because it can be pricey if not.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    That's funny, I had the same situation. [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/75K5>http://coloradok5.com/gallery/75K5</a>
