Where can I find a 1/2" block/shim??
Discussion in 'The Garage' started by FreedomIsntFree, Aug 31, 2005.
  1. FreedomIsntFree
    FreedomIsntFree 1/2 ton status
    Aug 23, 2005
    124
    DFW, TX
    So my blazer is sagging on the drivers side. I just installed 4" blocks in the rear and I did new springs up front. I measure from the top of the ubolt plate in the rear to the frame right above it and i'm sitting about a 1/2" lower on drivers side.
    So I just want to get a 1/2" block to correct the problem. Where can I get one?
    If I can't, what would you guys recommend? I did a search on truck lean and couldn't find anything.
  2. 2High4U
    2High4U 1/2 ton status
    Aug 20, 2005
    542
    Felton Pennsylvania
    easy temp or long term fix
    just use a piece of wood you can make that yourslef and its cheap if not look for a thick peice of metal add pieces weld them together there are probably other things that you can buy if i run across anything ill let you know
  3. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    I wouldn't stack blocks. And definitely wouldn't use wood, unless it is only to check out how it looks in the driveway and then removed before driving.
    Is there some reason why it is lower on the one side? Maybe the way the truck is loaded or something. Maybe there's something wrong with that spring.
    I would say live with it until you can afford new rear springs.
  4. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i hope your NOT talkin about putting the piece of wood inbetween the axle and spring :eek1:
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    mill 1/2" inch off the high side spacer block.... :D
  6. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    Misinterpratation
    Sorry I thought he was talking about the back blocks i heard of that being done before. I could still be wrong. I think Autozone has those cheap lift\Lowering kits somwhere fo like $20
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Back or front, wood is NOT a material to be used in suspension systems unless you're building a soap box derby racer. :eek1:
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Get one extra overload leaf and a new center pin. Cut the ends off of the overload leaf, leaving about a 6-inch piece right at the center hold area. You now have a low-buck 1/2-inch zero rate that you can add to the bottom of the sagging spring pack. :cool1:
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    I have done this, but most of the overloads I have found are actually 3/4". At any rate, I agree. There will be something in your local junkyard that can be cut to make this spacer. Then just bolt into the spring pack.
  10. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    You're talking about the rear? correct? If so, I may have a solution for you. PM me.
  11. FreedomIsntFree
    Aug 23, 2005
    124
    DFW, TX
    Not a member...I know I know...i'm working on it. You got e-mail?
  12. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Sent you an e-mail.
  13. FreedomIsntFree
    Aug 23, 2005
    124
    DFW, TX
    Replied...thanks.
  14. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    call your local steel supplier, you can get a 4" long peice of 1/2" x 2" flat bar remnant (scrap) for around $5 here. drill a hole and bolt it into the leaf pack, or weld it on the perch
