Where can I find info on 6.5 Diesel engines?
Discussion in '1982-Present GM Diesel' started by Blazer79, May 26, 2002.
  1. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    A good friend of mine just bought a 1990 4wd 1ton truck. It has a 6.5 diesel engine that needs some good care, especially the injection stuff. Where can I find some good info on these engines? I'd like to find something like this forum but for 6.5L engines.
    Thanks.
  2. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
  3. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Ditto on what Oblin said, 'though the 6.5L was actually introduced in '92 in some applications.
    The 6.5L and 6.2L are nearly identical, so the guys here and over on the diesel page are the best on the net. The 6.5L is based on the 6.2L, with just a larger bore and better heads. The external parts swap over, which means you can install 6.5L heads on a 6.2L and vice versa.
    However, the '94 and later trucks have electronic injection pumps, and that requires special knowledge to work on.
    Casey
  4. Blazer79
    1,816
    Thanks for your posts. I just registered on that site and I'm waiting for my activation.
    There is a good chance that the engine was swapped in this truck. Is there a way to tell the difference between the 6.2 and the 6.5?
    Thanks again.
  5. arveetek
    Mar 1, 2002
    722
    It's hard to tell the difference between the 6.2L and 6.5L The easiest way to tell is to see if there is a sticker on the driver's side valve cover which will state that it is a 6.5L, and give all the HP specs and such. If that sticker is not there, then you'd need to get some numbers off the block and heads to find out for sure what it is.
    Casey
