Where can i find new u bolts and spring plates?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AmericanFreak, Apr 17, 2003.
  1. AmericanFreak
    AmericanFreak Registered Member
    Jan 6, 2002
    40
    Shillington pa
    need to know where i can find a good set of new u-bolts and the top spring plate for a FF 14 bolt?
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    MY GM DEALER TOLD ME UPPER PLATES WERE ABOUT $17, DIDN'T ASK HIM ABOUT U - BOLTS THOUGH....
  4. yellow81k10
    yellow81k10 Registered Member
    Apr 1, 2003
    15
    Parma Idaho
    /forums/images/graemlins/usaflag.gifcheck out offroad design they have a kit that comes with the spring plates, u-bolts, nuts and all /forums/images/graemlins/truck.gif
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Stock replacement ???? or for larger axles like the 14 Bolt FF ???
  6. AmericanFreak
    Jan 6, 2002
    40
    Shillington pa
    ALright guys thank you
  7. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    I ASKED ABOUT THE 14 FF, FOR WHEN I PUT MINE IN, I HAVEN'T CONFIRMED OR LOOKED AT HIS PIC. WILL CHECK FURTHER WHEN I BUY....
  8. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    best place to get u bolts is from a local spring shop. they can bend them to whatever size you want and its generally cheaper than buying aftermarket ones that may or may not be the exact size you want.
    j
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    if you have any plate steel layin around you could easily make the upper plates. . .and it you want to make them really heavy duty- weld some vertical pieces to the top going parallel to the axle tube (like angle iron) that what a friend of mine did. if i could ever find a good supply or place to buy plate steel i'd do the same.
  10. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    www.truckpro.com if there is one close to you. They'll tell you what they need to know and then bend them for you.
  11. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    Paid $20.00 for the pair of spring plates at a local junk yard. Just go find a truck with 14 bolt and you are set.
    U-bolts I think were about $11.00 each from NAPA. 3 1/2" spread, by 5/8" thread diameter, by 8 1/2" long.
