where can I get 14 blt spring plates???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueOx, Sep 3, 2002.
  1. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    I have looked at most all the parts yards around and they all take the axles off the vehicles to sell them. I guess they get rid of the spring plates. I called the dealed and they were no help. Oh and U blots.
    Thanks,
    Charles
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
  3. tRustyK5
    Jul 23, 2000
    36,184
    1,388
    E-town baby!
    I used a dremel to open the holes a little on my half ton plates...works fine and they've been like that for 5 years. It doesn't take much, 1/8" on each hole outwards and they should slip right through.
    U-bolts can be had at any spring and suspension shop near you. The 14 bolt has a 3.375" tube diameter...length is whatever you tell them to make it.
    rene
  4. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    Offroad sells them but it gets a little pricy (they said they were a small place and no discount to K5 members). The local truck shop bent up ubolts for $35 (they can make any size you want). I cut 1/2 ton plates down the center and welded a flat bar spacer in.
  5. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    post a WTB post here on ck5, thats what I did. Alternatively you could make some, they are just a plate o steel with holes for the u bolts and a hole for the spring center pin. pretty simple. If you wanted to go the later route I could measure mine for ya...
    J
  6. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    If you dont find any I am making some for a friend tomorrow. Let me know and I can make two sets. $20.00 for the pair plus shipping.
  7. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I'd be interested in some of those. What is the material and constuction method? I like my junk hideously overbuilt /forums/images/icons/grin.gif </font color>
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Look for the smaller junkyards. I got my 3/4 ton plates (to flip those ridiculous 1 ton "nut on the bottom" plates) at a local u-pull-it. IIRC the pair (no rust other than surface, no dings, clean threads) with u-bolts cost about $5...
  9. Butch
    Apr 26, 2000
    1,338
    Austin, TX
    I make them out of 1/2" Plate with the holes you need and the edges eased on them
