Where can I get A/c hoses?
Discussion in 'The Garage' started by afroman006, Jun 27, 2005.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I need a new hose for the a/c system in my 98 Chevy K3500. I've checked auto zone and o'reilly's and neither have the hose nor can get it. Anyone know of a place where I can get one?
  2. puckhead
    puckhead 1/2 ton status
    Jun 17, 2005
    112
    colorado
    Carquest usually has common hoses in stock(depending on the size of town) if not they can order them and some places like napa or carquest even build hoses on site so call around and check it out
  3. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    Vintage Air has just about everything you'll need... either that or Southern Air
  4. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Hoses
    Look in your yellow pages for a place that MAKES A/C hoses. It's often cheaper than buying premade ones, and the quality is usually better, since it's usually made by hand, and not mass produced. PLus, if you want to route the hoses a different way to get them out of your way, or make the engine compartment look neater, they'll make them any length you want, with whatever fittings and ends you need on them. Bring the old hoses with you, alot of time they can reuse the old ends, or at least they know which ones nedd to be put on.
  5. LongIslander26
    Jun 25, 2005
    256
    A/C Hoses
    Look in your yellow pages for a place that MAKES A/C hoses. It's often cheaper than buying premade ones, and the quality is usually better, since it's usually made by hand, and not mass produced. PLus, if you want to route the hoses a different way to get them out of your way, or make the engine compartment look neater, they'll make them any length you want, with whatever fittings and ends you need on them. Bring the old hoses with you, alot of time they can reuse the old ends, or at least they'll know which ones need to be put on. :waytogo:
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I have had good luck with NAPA for hoses. They either have them, can order them or can make them.
