where can I get anti squeak material for the gas tank straps?
Discussion in 'The Garage' started by weisel, Feb 6, 2003.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I need the stuff that goes between the gas tank and the strap. LMC has it, but I was curious if I could buy it localy and soon.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Hmm, seems to me that a couple of strips of roofing felt would work pretty good. You could probably find a scrap for free at a construction site. /forums/images/graemlins/cool.gif
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I agree with Harry, thats about all it is is roofing felt.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    i duct taped my old ones back together and reused them...put a flat cardboard box between the tank and skidplate so they would stop rubbing together and rusting
  5. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    I used bicycle innertubes,worked OK. /forums/images/graemlins/thumb.gif
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    [/ QUOTE ] But cardboard will hold moisture and cause rust. /forums/images/graemlins/shocked.gif Roofing felt is waterproof so it won't hold moisture against the tank. /forums/images/graemlins/cool.gif
  7. Chris87K5
    Chris87K5 1/2 ton status
    Sep 21, 2002
    322
    Pennsyltucky
    I used roofing felt on mine too and works fine.
  8. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I've bought the stuff from LMC and it just like roofing felt. If I had known that I would of just used some 15lbs felt.
    Eric
  9. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    In reply to:
    But cardboard will hold moisture and cause rust. Roofing felt is waterproof so it won't hold moisture against the tank.
    yes i know...i sanded the tank down since there was some rust on the surface and painted it with some POR 15 i had...forgot to mention that part
  10. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I also used an old bicycle tube, seemed to work great
  11. sidslc
    sidslc Registered Member
    May 27, 2002
    96
    slc ut
    I cut up a old rubber truck bed liner. Works great I think a floor mat would work also.
  12. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    Wow! losts of good ideas right away. Thanks for all the info. I found some nylon straps that are cut
    up and I will probly use those. When I do my blazers tank, I'll probly use the roofing felt.
  13. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Every major city has a freightliner dealership...tank straps on a FL70 have rubber isolaters that halve a small lip on the outside edge to keep them on the strap without glue....i'll try and get a part number for you next week.
    DW
  14. grumpy
    grumpy 1/2 ton status
    Jan 7, 2001
    353
    San Diego, CA
    Did you ever come up with the part number for the tank strap isolator material?
    David
  15. K5 NUTT
    1,611
    Its 906 pm right now...if you call the FTL dealer in phx 1-888-414-2211....ask for Dave Olvey in the body shop (fellow owner of twin K5's)...he can get ya the PN# right now...he just sent me 4 in the mail...
    Doug W
  16. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    you can cut up a old piece of heater hose and use that, its what i did and no squeeks
  17. K5 NUTT
    1,611
    680-475-01-48
