Where can i get cheap shims.
Discussion in 'The Garage' started by k5freak44, Oct 14, 2004.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    I want to fix my caster angle wich is now at 9.4 degrees. Where can i find a cheap shim to fix this problem and solve my death wobble for good. I am looking for a 7 degree shim.
    Also if my angle is 9.4 now, and i want it to be 2.4 by adding a 7 degree shim, do i put the small part of the wedge up front in in the back?
    THanks
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You might have to get something made. If I remember correctly, they dont go that big.
  3. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    I just made a couple set for myself. Do you know anyone that is a machinist? Doesn't take too long to do. I'm making another set next week maybe I can do one for you also /forums/images/graemlins/thinking.gif.
    -Chris
  4. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah seem good. The aluminum ones always mushroom on the corners, or crack, or both.
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    yea those look good, just dont get aluminum they are crap /forums/images/graemlins/thumb.gif
  7. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
  8. diesel4me
    Jul 24, 2003
    17,540
    927
    Massachussetts
    I saw some cheap shims on a bronco at a truck and car show--the guy simply cut a peice of an old leaf spring off near its tapered end,and drilled a hole in it for the center bolt.Dont know if its a good way to go--but it seemed to work for him. /forums/images/graemlins/crazy.gif
  9. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    azkickin is kinda pricet i think i will juist stick with the ones i found
    thanks guys.
    oh and to i put the fat part of the wedge faceing the front or the rear if im trying to reduce my pinion angle. my guess would be toward the rear
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the azkickin come with a center pin bolt and the JWK do not. plus you get a discount from azkickin for being a CK5 member.
    the fat end in gonna bring that side down. if you put it of the rear, its gonna tilt the front up and the rear down.
  11. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    if you want one end of the axle to tilt up, fat part of the shim goes on the opposite side.
    are you putting these on the front or rear axle? i know you said u want to fix the caster but i think you mean on the rear, which is not caster, just pinion angle
  12. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    front. im trying to eliminate my death wobble
