Where can I get pre-bent fuel lines?
Discussion in 'The Garage' started by muddermilitia, Jan 3, 2007.
  1. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Ok so I just finished changing the fuel filter on my 88 k-5 and I turn the key to prime the pump only to find out that a fuel line has a hole in it now. :mad:
    The hole is about halfway between where the filter is located and the gas tank. Its right where three lines are clamped together.
    So does anyone know where I can get a pre bent line from? :ears: I need to get this truck rolling soon. I already checked the LMC website and it appears that they only sell fuel line for carb'd trucks(73-86) not TBI(87-91)
    Thanks- Ryan
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Just cut the bad portion out and install a flare fitting then flare the line. Do this to both lines after it has been cut then use a union to connect them back together.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
  4. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Thanks for the quick replys guys.
    I think im gonna have to do what 4X4HIGH said. If I had the money I would replace the lines. My trail rig is sucking the money right outta my wallet
