Where can i get some an fittings for fuel line?
Discussion in 'The Garage' started by 5trucks, Feb 26, 2007.
  1. 5trucks
    5trucks 1/2 ton status
    Aug 12, 2005
    169
    Yuma Az.
    Want to connect my 8an fittings to regular fuel line. Do they make a fitting i can just put on or do i need to order all sorts of stupid crap to make it work?
  2. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    I just went through all this trying to figure it out. I wasn't able to find any saginaw to AN fittings. My current plans are to just replace the whole line and use AN fittings the whole way.
    Someone correct me on this but I think you could cut off the flare and use one of those tube & socket fittings which depending on the size of the tubing (likely 3/8") will get you -6 AN. I think the -8 only came for 1/2" tube.
  3. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Earls auto fit for the tube. it ha a -6 end for the 3/8" fuel line. they also make male saginaw to male -6. BTW -8 is 1/2" and tooooooo big.
  4. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    You didnt tell us what you are hooking it up to, but
    Try this guys site and look under mods, and fuel lines.
    http://z28boy.cz28.com/main.htm
    He has info and part #s for MM to AN fittings.
    Now I dont know if that is just different terminology for saginaw fitting, but it is still GM, so it may work for our trucks.
  5. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Summit has Saginaw to AN -6, I have it on my TPI...
