Where can I get Specs HELPPPP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GRINCH, Dec 17, 2001.
  1. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    I installed a 1996 Vortec crate motor with the Edelbrock MPFI. I ordered the 12530283 motor rather than the 12530282. The 83 is the heavy duty motor. I need to know if the cam and compression is the same. I've been fighting with edelbrock for 6 months now. The truck is running rich and the Intergrator and BLM #'s are always below 128, usally hanging around 118-121. I have the tell tale signs also sooty exhaust tips, poor MPG and carboned up plugs. I have a engine data scanner (Turbolink) and all my other readings are fine.
    I have been searching the web for the spec with no luck. '
    Can anyone help........
    The Few, The Proud, The K5 Blazer
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    A GM parts shop can't provide the info you need on the two blocks? Just a thought... don't mean to be a wise @ss! [​IMG]
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
  3. GRINCH
    Jan 30, 2001
    1,951
    Helena, MT
    Tried both Pace and Scoggins.... I will try again maybe I got a moron at each!!!!!
  4. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Don't know much about MPFI, but I've been troubleshooting a rich condition in my TBI Camaro for a while now. I've tried just about everything, and it looks like I'm going to have to get, yet another, EEprom burned to resolve it.
    Like you, the BLM count only goes to 128 at wide open throttle, and hovers around 117-122 during normal driving.
    Good luck,
    Thomas.
    -- '84 1-Ton Blazer --
    When the goin' gets tough,
    the tough go 1-Ton [​IMG]
  5. GRINCH
    Jan 30, 2001
    1,951
    Helena, MT
    What scan tool are you using?
  6. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    It's a program called WinALDL, written by a member of Home Page
    The program is free for download, and I built the interface cable from $9 worth of Radio Shack parts; but it is specific for TBI units. It has been invaluable in tuning my Camaro!!
    Thomas.
  7. eds77k5
    eds77k5 1/2 ton status
    Oct 19, 2001
    383
    washington state
    not sure if this is what you want:
    <a target="_blank" href=http://www.automotiveweb.com/EngineTech/gm.htm>http://www.automotiveweb.com/EngineTech/gm.htm</a>
    you have to scroll way down the page
    "growin old is not for sissies"
    77k5 400/350/np203/stock for now
  8. GRINCH
    Jan 30, 2001
    1,951
    Helena, MT
    Stoopalini,
    Thanks.. But the site is down or a bad link. The MPFI uses the stock ECM and wiring from the TBI Harness. Edelbrock is sending me a new chip with the fuel mapping turned down a bit. We will see if it works... Doubtfull....
  9. GRINCH
    Jan 30, 2001
    1,951
    Helena, MT
    eds77k5,
    Not quite what I was looking for, but Thanks....
    I really need to know the difference between the two. Cam, compression. I did find that the HP and Torque ratings were different. I find it hard to believe this is turning out so difficult.
    Thanks for your help..
  10. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Hmmm, the link is working for me? Here is the actual address if you want to check it out:
    <a target="_blank" href=http://w1.601.telia.com/~u60113744/software/winaldl/winaldl.htm>http://w1.601.telia.com/~u60113744/software/winaldl/winaldl.htm</a>
    I understand on the custom EEprom thing. This will be my 3rd EEprom on my Camaro to get the fuel curve correct. At least the corrections to the original config are much cheaper than the original burn.
    Good luck, hope you get it worked out .....
    Thomas
