Where can I get spring perches and shock mounts for a 14 bolt?
Discussion in 'The Garage' started by afroman006, Jan 19, 2004.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I'm rebuilding my rusty 14 bolt ff and since its a 1-ton I need new spring perches for sure and I decided to ditch the stock shock mounts as well because they were really rusty and hung down too low for my tastes. I was looking for the echobit website because I've seen both spring perches and shock mounts that I like there before but could come up with nothing but the forum page. Do they still make all this cool stuff? IF they dont, where can I get them? Thx.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Pm TONYP, he makes them....i can also if you can't get ahold of him /forums/images/graemlins/thumb.gif
  3. afroman006
    Aug 21, 2002
    2,876
    Shock mounts too? I want shock mounts with the bottom sittin even with the axle tube. Can you do this?
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    yes i can....pm me
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    I also agree that TONYP is the man for the parts. His shock mounts are AWESOME! /forums/images/graemlins/wink.gif
  6. audacious
    audacious Registered Member
    Mar 10, 2003
    34
    tx, austin
    i need the hook up on the 14 setup also. i am putting the rear end on my blazer and need new set of mounts. thx
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    man i need to get on here more, sight looks to be running fine now...
    here are two of the parts your looking for...
    [​IMG] [​IMG]
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    [hijack]Do you make them for Heeps too (2.5" axle tube diameter)?[/hijack]
    Those are almost too pretty to weld to a rusty old axle...
  9. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Wow /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif Tony those are nice I keep seeing your work on ck5 good stuff /forums/images/graemlins/waytogo.gif. I'll definately need to order some of thos shock mounts for the 14b when I do my suspension this summer /forums/images/graemlins/woot.gif. Can you PM me with a price. /forums/images/graemlins/thinking.gif/forums/images/graemlins/thumb.gif Thanks
    Jesse
  10. audacious
    Mar 10, 2003
    34
    tx, austin
    /forums/images/graemlins/waytogo.gif exactly what i was looking for tony i would like to purchase a set as soon as possible let me know the price. they look like great work. i need to install them on my 1ton 14bff. so i can finish my setup. thx
  11. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    I have Tony's shock mounts, they're great! Lots of welding surface for a strong connection to the axletube, nice and thick so they'll take a pounding, and they work perfectly when they're installed in a position with nothing hanging below the axletube.
  12. 89BlazerK5
    89BlazerK5 1/2 ton status
    Aug 24, 2002
    134
    sorry to hijack..... but, tonyp.... do you also make these?? do you sell them?? i might be in need of a set in the near future.
    btw... nice work /forums/images/graemlins/waytogo.gif
  13. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Can't see the pic....sez I'm forbidden... /forums/images/graemlins/dunno.gif
  14. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Does anybody have a pic of Tony's shock mounts welded on? I am in a quandry. I cut my shock mounts off my Corp14ff because the rig it was going in, had cracked upper shock mounts. I planned on going with the MOO upper inboard shock mount setup w/ the combo truss/shock mount on the axle. Now I have a different rig and the upper shock mounts are fine. So, I'm torn between welding on lower mounts and using the stock uppers, or staying with the inboard setup. What do you guys think?
  15. gzzgfw
    gzzgfw 1/2 ton status
    Feb 26, 2003
    505
    Also check out
    www.ubmachine.com
    located in New Haven , Indiana
    they cater to the race crowd but have alot of fabbed parts like perches, mounts, caliper brackets, ect. that save a bunch of time to make. good luck
  16. TONYP
    Aug 13, 2002
    2,116
    so cal
    here's the print for the install...
  17. 89BlazerK5
    Aug 24, 2002
    134
    tony..... do you make the 8 lug to 6 lug adapters?
  18. retroblazer
    retroblazer 1/2 ton status Premium Member
    Nov 30, 2003
    280
    148
    Gustine
    I'm installing a 14 into my 94 k1500. Has anybody done a dual shock set-up?
  19. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    I got my new spring perches from the local chrysler dealer, just ask parts for spring perches. and I got my shock mounts from the nice people at skyjacker suspension. perches about 15.00 a pair, shock mounts about 9.00 a pair /forums/images/graemlins/thumb.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
