Where can I get these?**UPDATE**
Discussion in 'The Garage' started by UseYourBlinker, Apr 10, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    <a target="_blank" href=http://coloradok5.com/gallery/My-1980-K20/aae>Here's a pic</a> .... I need the brake line holder on the shock. I need two of them...Anyone know where I can get them?
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Re: Where can I get these?
    I blew up the pic and the line says procomp....I know its not the holder, but maybe its something you can get from them.
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Looks kinda like a zip tie to me.
  4. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    USE A ZIP TIE WITH A LOOP IN IT AT THE SHOCK. NOW SOME TIMES THE BRAKE LINE IS SO LONG THAT IS TOUCHES THE TIRE (LIKE MINE). WHAT YOU DO IS GO TO AN AUTO PARTS STORE AND GET A CARB. SPRING PACKAGE (IT HAS ABOUT 6 OR 7 SPRINGS IN IT) AND SCURE ONE SIDE SIDE OF THE SPRING TO THE FRAME AND THE OTHER TO THE BRAKE LINE SO IT PULLS IT AWAY FROM THE TIRE. WHAT IT WILL DO IS KEEP THE LINE OFF THE TIRE AND STRECH WHEN THE TIRE DROPS. IF YOU NEED ANT PICS. LET ME KNOW.
  5. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    After looking at it a few more times I recognize parts of it. The clamp is just a rubber lined fuel line type clamp that you can get at most part stores. It looks to be zip tied to the shock, but I dont see how the clamp is secured to the zip tie. Then it appears to be fuel hose over the braided line that is zipped at both ends to hold it shut from where he sliced open to go over the braided so it will fit the line clamp.
    Did any of this make sense????????????
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    They come with RS900's, but the guys have it right, you can get the same effect with zip ties and rubber-lined fuel line hold downs. Probably cost ya $2 total.
  7. Re: Where can I get these?
    LoL I was reading the post waiting for the picture to load and I was thinking to myself wait.... I have those and sure enoguh it's my truck ing the pic. Yea it's simple they are little clamps that have a rubber lining and then there is a little slot and two zip ties go through there to hold it to the shock. The it's fuel line cut lenght wise and then zip tied to each end. It works real well and the brake line never gets hung up on anything and stays out of the way of the stearing arm etc.
    80K20
  8. UseYourBlinker
    Jun 7, 2000
    11,117
    Went to the hardware store and found a 5/8" rubber lined clamp,and zip ties... <a target="_blank" href=http://coloradok5.com/gallery/albuq29/aaa>So I mde my own for $1.29</a>
    THANKS FOR THE HELP GUY'S!
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The "rubber lined clamps" are used extensively in aircraft. They're called Adel clamps. /forums/images/icons/cool.gif
  10. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Did you get the 4" lines from Procomp?
    Also, whatch out when you have your sway bar connected. I mangled the hold up bracket on mine with a 2.5" lift.
    Have you tested the flex out with the new lines and sway bar disconnected?? What shocks are you running and waht size(lift type) are they for?
  11. UseYourBlinker
    Jun 7, 2000
    11,117
    **Yes...got them from BIGJ on this site**
    **Yeah I am aware of that**
    **Haven't yet...April 21st at Hollister I will**
    What shocks are you running and what size(lift type) are
    they for?
    ** I am running Procomp 3000's for a 3 inch lift. **
  12. CK5
    May 19, 1999
    21,623
    701
    CO
    I plan on carring the extendo ss lines here also, stay tuned...
