Where can i get turn stops and why am I breaking them?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SCOOBYDANNN, Apr 10, 2003.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Just got back from doing a little wheeling and noticed i broke the driver side steering stop and noticed also that there are wear marks on the axle u-joints themselves (obviously because they are turning too much. I am pretty postive i mounted the ram correctly but im guessing the ram is still pullin even though the "stop" has hit. is there a way to limit the ram????? /forums/images/graemlins/confused.gif
    thanks
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I replaced my stops with G8 bolts. I have bent one, but not broken it. One of the guys out here runs stacked washers under his to take up the space. I'll probably be doing the same...
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    I talked to brian waddel the other day and he said he drilled out that hole, and tapped it, to accept those honkin ass Torx seatbelt bolts.....
  4. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    thanks
    You can put a spacer on the inside of the ram body to limit its travel. /forums/images/graemlins/thumb.gif
  6. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    When I broke one, I drilled the hole out and used a 3/8" ARP bolt. I just ran the bolt thru from the back and put on a GR.8 nut and some red locktite, then cut it to legnth (measuring the other side) and it has been working fine. I know that's not what you asked, just wanted to give you an option.
  7. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    On farm equipment it is common to use large aluminum washer type things to limit the stroke on the hydraulic ram used to raise and lower the tires. This determines how far the implement goes into the ground. I would think you could find or fabricate something to limit the travel on your ram.
    The spacers are basically two half moon clips of aluminum with a spring steel retainer on the horizontal axis. Kinda like a c-clamp.
