WHERE DID THIS DANA 60 COME FROM
Discussion in 'The Garage' started by FLASHLIGHT76, Jul 24, 2002.
  1. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    I JUST AQUIRED A DANA 60 REAR WITH A LOCKER AND 4:10''S FOR MY SUB. THE OWNER THINKS IT CAME OUT OF A CHEV LATE 70'S. THE SPRING PERCHES ARE VERY NARROW BUT ARE THE RIGHT SPACE APART FOR MY TRUCK. IT IS A 8 LUG PATTERN AND FITS MY TIRES. THE SHOCK MOUNTS BOTH FACE FORWARD AND THE DRUMS HAVE TWO SCREWS HOLDING THEM ON. UNFORTUNATELY THE RIGHT SIDE IS MISSING ALL THE BRAKE COMPONETS SO I KIND OF NEED TO KNOW WHAT TO ASK THE PARTS GUY FOR. ANY IDEAS, SUGGESTIONS, OR EVEN POSSIBLEY INEXPENSIVE DISC CONVERSIONS? HELP!!!!!
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    My genuine '77 Chevy service manual list the Dana 60 so it was used in something that year. This is in the rear axle section of the manual.
  3. FLASHLIGHT76
    Jun 20, 2002
    255
    OREGON
    ARE THERE ANY IDENTIFYING MARKINGS THAT I CAN LOOK FOR?
  4. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Since both shocks face forward it may have come out of a '71- '72 truck.
  5. tRustyK5
    Jul 23, 2000
    36,184
    1,391
    E-town baby!
    If it came out of a 68-72 era truck the perches would be wrong for a 73-87 gen Suburban.
    4.10's and a traction aid sounds like a pretty common Ford rear end. I have no clue if the perch width was similar to Chev though.
    Rene
  6. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Is this a semi floater or full floater axle? If it's a semi floater I would think tRustyK5 is right about it being a Ford axle. You need to clean it real good and find the Build of Material number on it (I think it's on the rear of the pass. side tube), this number tells everything about the axle (application, year, gear ratio, etc). There is a Dana site where you can decode this number but I don't know it, MJ knows it - maybe you'll get lucky and he'll see this thread.
    Good luck.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    I agree with tRusty, sounds like its from the '67 to '72 era and if its not a GM axle, it sounds like the Ford axle because all Fords have the rear shocks on the forward part of the housing. /forums/images/icons/wink.gif
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the removeable drums sound like a ford too,
    didnt they set theirs up so you didnt have to pull the shafts to do brakes.
    http://www2.dana.com/expert/
    the weird part is I was just typing your name into a reply then came here to see you were typing mine /forums/images/icons/tongue.gif
  9. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Yeah, I think it's the Ford 10.25 rear axle that the drums slip off of without having to pull the axles, not really sure.
    By the way, great minds think alike! /forums/images/icons/grin.gif
  10. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    That sounds alot like the rear Dana 60 that I pulled from a 67 GMC C20. The drums come off by removing 2 countersunk screws.....without pulling the axles. Both shock mounts point forward. The 2wd Dana 60's of the 67-72 era have a spring pad spacing of 42.5" The 4wd's spacing is 40". My axles has 30 spline 1.3125 diameter axles. Hope that helps. /forums/images/icons/grin.gif
  11. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    That also applies to 63-66 GMC's also (but Chevy was a different deal altogether!).
  12. FLASHLIGHT76
    Jun 20, 2002
    255
    OREGON
    WELL TO ANSWER SOME OF YOUR QUESTIONS. IT IS A FULL FLOAT DESIGN, YOU DON'T HAVE TO REMOVE THE SHAFTS TO GET THE DRUMS OFF AND THE STUDS ARE A SMALLER THREAD SIZE THEN MY CHEVS. IT'S STARTING TO SOUND LIKE A FORD TO ME BUT I JUST WANT TO BE SURE. THANKS /forums/images/icons/grin.gif
