Where did you get your 8-lug conversion parts?
Discussion in 'The Garage' started by jms, Jul 23, 2003.
  1. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Where did you guys get your 8-lug conversion parts? Local Napa sez junkyard for caliper supports and hubs; rotors are no problem, and as I understand it the spindle is the same as my '85 as long as I get '77 or newer hubs. Any place I can get hubs and caliper supports new/reman? Appreciate the help, I'm getting anxious to get the truck off the jackstands.... thanks, michael
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I got a decent set of hubs and caliper supports from a local junkyard for about $50. Cleaned them, painted them, repacked the bearings and bolted them on. I'm sure you can get new from the dealership, but expect to pay quite a bit.
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I bought the conversion parts for my Dana 44 used from a guy on the Pirate board.I got the backing plates,hubs,rotors,and bearings for $200.All the parts came from a 10 bolt. /forums/images/graemlins/grin.gif
  4. blazerboy72
    blazerboy72 1/2 ton status
    Mar 29, 2002
    260
    hiram ga
    i got all of mine off a guy on pirate but they are all screwed up so they are setting in my basement. i think autozone and advance autoparts sell new hubs but they are expensive.
  5. jms
    Jan 24, 2001
    1,683
    Just checked at the dealer, $441 for one rotor-wheelstuds-hub assembly, $96 for one caliper support.... /forums/images/graemlins/blush.gif
  6. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,259
    72
    Humboldt/Pacifica, CA
    Did you read the 6 to 8 lug conversion write-up and call the company that is listed in there?
    I also see thebigdaddyof2 selling these parts every once in a while, that's who I got mine from.
  7. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I bought my rotors at AutoZone for $25 each. They also had a hub rotor assembly for about $110. The backing plates can be a little scarce. I bought the whole front end from a junkyard for 3 bills. It hurt but I was tired of carrying two spares around. If you're gonna use 15" wheels buy some extra grinding wheels. As far as the calipers I used my 1/2 tons, the 3/4 calipers were bigger and wouldn't inside my 15" wheel. Now that I want to do the rear disc conversion they've dissappeared /forums/images/graemlins/angryfire.gif
  8. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    well if you still have the 6 lugs rims and tires mounted you could just convert your rear axle from 8 lug to 6 lug...
    8 to 6 lug kit
  9. jms
    Jan 24, 2001
    1,683
    Thanks for the replies. One reason for converting is that I WANT the bigger brakes (I learned that in Moab last year). I've got the new tires and wheels already sitting around (315/75x16 MTRs on 16x8 black rockcrawlers). The rear 10-bolt is out, and a D60FF w/ ARB and disk brakes is sitting in its place. Hope to finish the rear end (brackets for e-brake cables and the lines etc.) this weekend.
    I'll try Autozone, thanks for the tip; would prefer to go locally rather than BorderParts (the company from the write-up) in San Diego. I've got to get the truck moving again so can get the front diff changed over to 4.56.
