Where did you mount your antanne?
Discussion in 'The Garage' started by zakk, Mar 28, 2002.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I got my CB and was wondering where people are mounting them. I was going to mount it back by the gas cap area, but I am worried a rock or brach will reach out and rip it off.
    Presently, I am thinking right below the rear driver tail light on a spring mount w/ 4-5' antanne.
    Any suggstions appreciated
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Got mine mounted to the top bracket of the tire carrier.It's only a 3' antenna but works for me.You can see a pic here,just look at the rear of the truck,it's a little hard to see.
    <a target="_blank" href=http://www.imagestation.com/picture/sraid29/p15c2acd724c88759b0d9370d62f3f807/fded6187.jpg>http://www.imagestation.com/picture/sraid29/p15c2acd724c88759b0d9370d62f3f807/fded6187.jpg</a>
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have to mount mine but I have everything to mount it on the driver side front fender. I have the bracket that goes between the fender and the hood.
  4. Grim-Reaper
    7,385
    Atlanta
    On the lady's 79 it's on the spare tire carrier. on my 75 it's sitting on the hood on the passengerside of the ridge. Better ground plane on sheet metal than if it's hanging off the side of the vehicle.
  5. LA Bogger
    LA Bogger 1/2 ton status
    May 19, 2000
    192
    Robins AFB, Georgia, USA
    I have mine mounted on the top mount for the tire carrier that isn't there any more 10 ft whip...:)
    Eat More Mud!!!!
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I have/had 4' whips on each mirror. I'm going to mount a single whip off the tire carrier so it won't get ripped off and mangled so much./forums/images/icons/tongue.gif
    Rene
  7. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Mines on the roof. I smacked the base on the drive thru at Burger King so I have it removed in some of my pics w/ a cover on the base.
  8. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Mine is on the side of my hood.... mount it to the truck because like Grim said on the sheet metal is the best and the higher up the better- is what the CB shop told me when I bought my CB from them....
  9. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    Got mine mounted right under the passenger side tail light. I got a 60" stainless steel whip on a spring mounted through a piece of 2x2x1/8" angle iron bolted to the body. If I get sick of it smacking the hard top I just stick it in the back window and it still gets great reception. Get an SWR meter from Radioshack for about $20 and tune your antenna, it makes a HUGE difference. I usually get stuck in the middle of the convoy on the highway cause my radio has the strongest Tx/Rx so I get to relay messages through the group. I ended up cutting 5 inches off my antenna and got it tuned to around 1.2 on channel 20.
  10. Snowbound
    Snowbound Registered Member
    Mar 12, 2002
    52
    Minot N.D.
    I mounted mine on the rain gutter above the passenger door.
  11. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    got mine on the side of the back bumper on the drivers side. mud knocks off the cable for it, and in high winds, it wobbles really bad and hits the truck making a lot of noise, otherwise i like it there
  12. gotmud?
    gotmud? 1/2 ton status
    Feb 23, 2002
    1,172
    up north
    jcg, that sig is hilarious! ROTFLMAO!!!!!!!!
  13. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    I use a mag mount assembly, which should be an indicator of how often I use my CB, with a cellular look-a-like antenna. It's also not a permanent fixture of my truck either (Velcro and cig plug). For my commonly used commercial rigs (VHF &amp; UHF), I use glass mounts on the forward top section of the rear side glass. I like the glass mounts because the element is easy to remove and there are no holes in my truck!
    They do make glass mounts for CB band, but they are a bit lossy with a long whip. I've seen high power units (with illegal linears) melt glass. A good mounting location for one of these would be the top of the windshield on the passenger side, rather than the side glass, to minimize lateral stress; assuming you're not an "illegal" /forums/images/icons/smile.gif.
