Where did you put your battery?
Discussion in 'The Garage' started by Sandman, Oct 20, 2003.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Looking for ideas for a battery relocation. The stock area is now gone and I can only think of three places:
    1. Behind the seat. Easy to set up but could be in the way.
    2. Behind the glove box. Really out of the way but a pain to service and hook jumper cables too.
    3. Where the heater and AC box used to be. Right now, this is my favorite like on a FJ40 or something.
    Any other ideas? Thanks.
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    What about the center hump between the seats?
    If a man had a wad of change, he could buy some of those mini batteries and have less placement problems.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    heaterbox is nice. My dad puts them there on all his circle track cars. Works nice, can use the box to make a hold down in some cases.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Mine is inside the frame rail behind the passenger seat.
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Why not move it all the way to the rear? Just inside the pass. side tailgate post? and run longer, heavier cable's to the starter. Build a box and lid out of 1/8" sheetmetal, bolt it to the floor.
    More weight is off the front end, and on the rear end. Extra lead's out the rear, for jump starting, winch, whatever. /forums/images/graemlins/grin.gif
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    mount it under your front passanger seat, HMMWV style. cut the floor and make your own custom "battery box" so that the bottom of the batt is a little above the bottom of the frame so it will fit under your seat no problem. Need to service it? flip up the seat!
    j
  7. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I have future plans to cut down and narrow the rear as well. Room will get tight back there with seats and relocated gas tanks. I think for now, I will look at putting it on the firewall. Maybe. /forums/images/graemlins/thinking.gif
  8. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I've found a good spot.... Stays clear of the front tire - even tho you'd think it wouldn't.
    Marv
  9. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I mounted mine on the hump behind the front seats. I recently took my two older kids along on a run, and it was out of their way. Just my .02! I liked the batt inside, away from the "elements."
  10. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    If you wanna put it in a box you can get a boat battery box there like $15
  11. 77ChevyK10
    77ChevyK10 1/2 ton status
    Feb 2, 2003
    317
    Laveen, AZ
    #3 mine is there now that i chopped the front
  12. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    i plan on moving bith mine right behind the cab, inside the frame rails, one on each side of the driveshaft.
  13. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    This is my batt box. Goes right in between the rear buckets. Batteries are positioned the long way with the blazer and two buckets just fit. Box is complete with insulation, hold downs, herculiner and cup holders for the rear passengers. /forums/images/graemlins/grin.gif
  14. hawglet
    hawglet 1/2 ton status
    Aug 4, 2000
    265
    Hastings,NE
    j
    I second the above or:
    The old CJ's had a hole just in front of the Pass. seat that could be made deaper and used for this as well. Also the 49-53 chevy pick-ups and panels had the battery mounted in this spot. A guy could actually use this design quite easily.
  15. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    FWIW, when I moved mine to the back, I also ran 00 copper stranded cables to the firewall for “+”. There it attaches to the high amp CUCV distribution buss using 3/8 soldered lugs. All power ties together on the buss including starter, main harness, and alternator. There are no additional wires hooked to the battery itself. On the battery, I have wing nut marine terminals with soldered and sealed lugs on the cables, very easy to unhook as needed without tools. “-“ goes to the frame with 1ga. cable. The batt(s) sit on a box/tray made from 1" x 0.120 angle and some 1" x 0.120 cold roll strap and bolted to the lower frame channel.
  16. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I like the idea of a distribution bus. Gives you an easy power source and you can put the battery anywhere. I'll have to look into that one. Thanks.
