where did you put your tranny cooler?
Discussion in 'The Garage' started by thezentree, Jan 19, 2004.
  1. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    im thinkin about installing an aftermarket tranny cooler, and i need a good place to put it where it wont get caked with mud, etc. its a 97 yukon.
  2. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    I put mine in the most obvious place, in front of the AC condenser. /forums/images/graemlins/thumb.gif
  3. fly_n_hi_yukon
    fly_n_hi_yukon Registered Member
    Jul 8, 2003
    44
    Strange Range, MI
    You can mount it almost anywhere, and in any direction, but the efficiency goes down as you move away from direct airflow in the front of the truck.
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    My factory trans cooler is over on the right (riders side) and the oil cooler is on the left (drivers side). Makes plumbing easier
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It needs to be right behind the grille with nothing blocking it for maximum effectiveness.
  6. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    I used the AC condensor as my tranny cooler. /forums/images/graemlins/thumb.gif
    But to answer your question,,, I agree with most folks here- in front of the AC condensor, right behind the grill is bout the best and most convienent spot.
  7. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    HA HA...in the trash can...Swapped to a stick..But really in front of the rad is the best place... /forums/images/graemlins/thumb.gif
  8. thefarside
    thefarside 1/2 ton status
    Jun 27, 2003
    343
    Vernon, CT
    I got some rubber hose then ran it though the floor I stick the tranny cooler out the window while I am driving. But not before I give my valve covers a good 100 shot of NO first. /forums/images/graemlins/wink.gif
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The front of your '97 Yukon should be fairly similar to our '94 Suburban. On the Sub I figured out that I could remove a couple of the screws that hold the side brackets onto the a/c condensor and then also use them to hold the left side of the tranny cooler in place. I had to drill one extra hole in the cooler bracket to line things up. Once I put the screws back in, the tranny cooler was being held very firmly, even though the other end wasn't supported. As much as I typically dislike the zip-tie-through-the-radiator mounts that come with most tranny coolers, using a couple of them on the other end of the cooler worked well in this case. The screws provide most of the holding power, while a couple of zip ties through the a/c condensor, with foam bumpers between it and the tranny cooler made for an extrememly rigid installation. /forums/images/graemlins/thumb.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Save it! I swapped mine over to the tow rig when I swapped the playtoy to an auto. /forums/images/graemlins/thumb.gif
  11. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Mines in front of the radiator, next to the a/c condensor. Makes the most sense. Easy to plumb it up with the cooler in the radiator.
