Where do i find the cable to attach to the gas pedal for my th400?
Discussion in 'Plains Region' started by rocko, Apr 30, 2003.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Anyone know what I need, what truck to look for? What's all included in transferring over to a 400 from a 700?
    I know some of you all have done this already... is it difficult? and what's done with the 4 prong plug in for the 700r4 when the transmission is removed?
    Thanks guy's.. trying to do my research before delving into the project..
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The TH400 doesn't take a cable. It uses an electrical switch that mounts on the gas pedal bracket. One side of the switch goes to a source that provides 12 volts when the engine is on, the other side goes to the connector on the drivers side of the TH400. When you floor it, the switch closes and sends 12 volts to the tranny, which activates the kickdown solenoid. /forums/images/graemlins/thumb.gif
    You can find the switch and wiring on any rig that came stock with a 400. 3/4-ton Subs and pickups, probably even some full size vans (Until '91, when the 4L80E started being used). I got mine from an old Jeep Grand Wagoneer. Back in the 70's they came with TH400's. /forums/images/graemlins/cool.gif
  3. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks Harry...
    How easy is this switch to install and how easy is it to remove from a donor vehicle?
    I'm going to try and gather everything up before I start doing the swap !!!
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    It's just held on the bracket by a couple of sheet metal screws. Your bracket most likely already has the holes drilled for them. /forums/images/graemlins/cool.gif
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I'm not sure but I think you can get it from Summit Racing...
  6. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    just come over and look at mine it is real easy to see and install /forums/images/graemlins/thumb.gif
  7. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    Hey Rocko
    What all do you need, parts wise to do the swap ?
    I have most of it, including the bracket for the kickdown switch.
    Are you going to a 400/205 or 400/208 ?
  8. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    Hey Rocko,
    Since you won't be needing the 4 prong connector (torque convertor lockup) anymore, I know Prescott sure could use this. He installed a TH350 with Lockup but hasn't gotten the lockup setup yet since he hasn't gotten one of the plugs yet.
  9. BILLY RAY
    Dec 8, 2001
    1,319
    Austin, Tx.
    he can have mine.
  10. 77 Mud Buddy
    77 Mud Buddy 1/2 ton status
    Oct 31, 2002
    228
    Austin, TX
    Sounds good to me! When can I come and pick it up?
    Prescott
  11. BILLY RAY
    Dec 8, 2001
    1,319
    Austin, Tx.
    uh!! when ever. You know where i live /forums/images/graemlins/rotfl.gif
  12. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    J20M715,
    I need the kickdown? or sensor..
    I'm going to a 400/205 picked up the pair for $450.00 with trans/tcase adapter and crossmember..
    It's missing the sensor and wire that attaches to the gas pedal..
    Billy.. I will have some time off here in the near future.. so i will stop by...
    Thanks guy's... I'm one step closer to getting the big white blazer back on the road.. /forums/images/graemlins/thumb.gif
  13. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    too the top.. i had problems getting into ck5 the other day... J20M715... I need the parts you have.. send me a pm please.. let's talk business.
  14. JAXSTER
    JAXSTER 1/2 ton status
    Mar 15, 2000
    181
    DFW, TEXAS
    This can also be swaped for Vacum controled Switch from older unit. then just run a vacum line to the Manifold.
