where do i find the engine codes on the engine
Discussion in 'The Garage' started by K-5kid, May 3, 2005.
  1. K-5kid
    K-5kid Registered Member
    Mar 24, 2005
    35
    el paso tx
    where do i find them? do i have to pull the motor? or can i just take the alinator and power stearing pump off? or is there another way to find them
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
  3. K-5kid
    Mar 24, 2005
    35
    el paso tx
    thanks i hope i can find it i will keep looking
  4. K-5kid
    Mar 24, 2005
    35
    el paso tx
    does anyone have a picture it where the code is i have looked where some sites say but i cant find anything
  5. dyeager535
    26,976
    I don't bother with anything but the suffix code. The location chart that was linked shows where it is.
    Passenger side front of engine, visible as you look down on it from above. Where the head meets the engine block there is a flat pad with stamped in (not cast) numbers. They aren't real big, and might be obscured by crud.
