Where do I get this part?!?!?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SkulzNBonz, Aug 26, 2002.
  1. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I assumed it was a tie rod end, but I must be mistaken. What I'm talking about is the end that connects the tie rod (?) to the driver's side wheel. The end also has a point to connect the steering stabilizer. According to both Autozone and O'Reilly's, this isn't a tie rod end, but I can't remember what they called it. This is of little consequence, since neither carry them, or have the part in their warehouse. What is the part actually called, and where the hell can I get one? BTW, this is a D44 axle. Sorry for my ignorance, and thanks for the help!
    John
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    It is a tie rod end, and those parts stores are dumbasses. My local Napa store had every variety in stock.
  3. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I figured as much! To NAPA after work it is. Thanks much.
    John
  4. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Funny, I bought mine at Autozone 2 yrs ago. And it's called a tie rod end. /forums/images/icons/shocked.gif
  5. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
  6. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I think that perhaps either I confused the auto parts guys, or they were stumped as to the whole solid front axle thing. I'm thinking the latter. Anyway, I appreciate all the help. I put some 33's on this weekend, and knew that I was about due to change the tie rod ends. With the extra weight of those tires and steel wheels, they decided they wanted to be changed NOW!!! I couldn't hardly keep the freakin' truck on the road! Thanks again all!
    John
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Be aware that there are 4 different tie rods. /forums/images/icons/shocked.gif
    To make sure you get the proper one, take yours off or drive the truck to the parts store to compare it to what they have or give you. /forums/images/icons/wink.gif
  8. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Thanks for the info. Can't hardly drive the truck anywhere like it is right now. I'll yank the tie rod ends and take them with me. Also gonna go through my Chilton's to find out the correct nomenclature of the rod end, so I don't sound like a complete idiot /forums/images/icons/laugh.gif /forums/images/icons/shocked.gif!
    John
  9. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    extra weight of the wheels /forums/images/icons/confused.gif
    i dried those things out at laketex's for a few months so they would shed some pounds /forums/images/icons/laugh.gif
    so, you got them painted and on the tires huh? /forums/images/icons/cool.gif
  10. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Yeah, I got 'em cleaned & painted, and mounted the tires Friday. I knew the tie rod ends weren't long for this world, but I guess that was the straw that broke the camels back! I got after tightening everything that could be tightened (ubolt's) with little effect. Can't hardly keep control of the truck at anything over 25 mph. Hit a bump and the truck started shakin' so bad I thought the front wheel was comin' off. Wheel bearings are ok, so tie rod and ball joints are my next logical step.
    John
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    it is just a tie rod
    I hope you are not describing your first 'death wobble' experience
    good luck in pinning it down
  12. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    NAPA had exactly what I was lookin' for, and understood when I explained it to her . NAPA calls them outer tie rod ends, Oreilly calls them steering arm to steering arm t rod ends, and they want double the $$ that NAPA wants. Thanks for all the help.
    MJ; I thought the same thing, but why would I get the dreaded "DW" when the only thing I changed was the tires from puny 31's to still puny 33's. Granted I did lift it a few months ago, but I've been driving it since then.
    John
