Where do I hook this thing up at?
Discussion in 'The Garage' started by hunterguy86, Jan 10, 2006.
  1. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Ok my Oil pressure guage is fluttering all over the place, so I got me one to replace it. Where do I hook the pressure line up at? Its a mechanical guage bu the way.
    This is goin on an 86 k5 w/ a 305
  2. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    Typically, it would go in the block next to the base of the distributor, where the factory electrical oil pressure sender should be. Pull the sender, and replace with the fitting for your new gauge.
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Is your stock set up mechanicle? Also was it a numbered gauge begore or just a high low set up or idiot light? This shouldnt matter tho if your new settup includes guage, line, and fittings to plug into block. It will be on block by distributor, tho Ive seen different fittings on different vehicles with small blocks. May need an adapter or something, may not.
  4. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I'm not sure if its mechanical or not. Its the stock, numbered gauge. If I had to guess I would say electrical. I dont remember seein an oil line when I had the dash out. I'll look at the dizzy tomorrow and see if I can see where it goes. Thanks for the input
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Look for something like this that threads into the block near the dizzy, there may be a wire connected to it. Take it out and install the fitting for the mechanical gauge in that hole.
