Where do y'all take your humongously wide blazers for an alignment?
Discussion in 'The Garage' started by muddin4fun, Jan 3, 2003.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Where do y\'all take your humongously wide blazers for an alignment?
    /forums/images/graemlins/rolleyes.gif
    I'm running 12.50's and NTB sent me to three different shops, all of which said my blazer was too wide for their machine.
    /forums/images/graemlins/1zhelp.gif
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Re: Where do y\'all take your humongously wide blazers for an alignment?
    All you need to do is set the toe-in. There is no need for an alignment shop, you just need a tape measure.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Really? I would have thought that 12.5's could have been done anywhere. the Big O tire and the Les Schwab have no problem with my 40's here although most of the time I align it myself with a tape measure. I just give it a toe in around 1/8 inch or so.
  4. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Dallas Frame and Alignment on Harry Hines (at NW Highway)...unless they have moved in the last 5yrs...Stay Completely away from Sundays shops as they Will Rob you...another maybe option is to swap out yer Fat Alberts for some stock size if you could find someone to let you borrow for a day...Hell, if it come down to it, I got 8 lugs street tires on my company truck...long as I can get it to work on Mon, I'm a happy guy...I'm off today (Fri) til Mon, so lemme know somethin', I'll PM ya my number... /forums/images/graemlins/grin.gif
  5. sluggo45acp
    sluggo45acp 1/2 ton status
    Jan 2, 2001
    472
    Northern fortress, Republic of Texas
    Hey lara where ya been? I use Bobby Gentry's here in Denton.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Lara, sounds like those alignment shops are giving you the run-around. /forums/images/graemlins/angryfire.gif
    12.5's are small stuff compared to the wider tires. /forums/images/graemlins/tongue.gif 12.5's rank up there close to the stock tire sizes and ANY shop should take/accept them and still get the aligning done properly.
  7. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Hey Lara good to see you around again. /forums/images/graemlins/grin.gif
    Personally I think your getting the run around since your trucks lifted ETC. A lot of shops dont want to bother aligning a lifted 4X4 since they figure youll just knock it out.
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I use a piece of 1x4...tape measures bend, the wood works great and you can mark it
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I am with the others here.
    if you are trying to troubleshoot a problem then a 4 wheel alignment can provide some info, but there is nothing adjustable in a straight axle chev other then toe.
    tools required are
    chalk
    a nail
    a tape measure/straight edge
    a jack
    a friend to hold other end of tape
    wrenches to loosen adjustment sleeve
    a pipe wrench to turn adjustment sleeve
  10. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Back when I used to work at Sears, I had my truck on the alignment rack there a few times with the same tires you have so it should fit.
  11. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Mieneke mufflers doesnt care just as long as the lazer thing can fit on the wheel without falling off. They are the only guys that didnt upcharge me either.
  12. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    What's the measurement for the toe?
    Oh, and
    Hi everyone! /forums/images/graemlins/grin.gif
  13. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    You measure the distance between the front of the tires and the rear of the tires and they should be equal to give you 0 degrees toe. As for straightening the wheel, drive the truck, if the wheel is cocked to the right, you got to bring IN the left tire as well as bringing OUT the right tire EQUAL TURNS until the wheel is straight. Its the opposite if the wheel is cocked left. /forums/images/graemlins/thumb.gif
  14. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Where did you go? Wal-mart did mine and I got 35x12.5 M/T on my truck.
  15. 96chevysfa
    96chevysfa 1/2 ton status
    Jan 1, 2003
    230
    so cal
    find a tire shop, i get lifetime allignment, dalancing and rotationg for 150. i robbed that place.
