where exactly is the delay wiper module on a 86?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gotmud?, Mar 27, 2002.
  1. gotmud?
    gotmud? 1/2 ton status
    Feb 23, 2002
    1,172
    up north
    and what does it look like, is it a pain in the arse to change? Thank's
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i might be wrong but i think its the black box mounted under the steering wheel...if you take off the metal panelling its right there.
  3. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I also have an 86. yep, it's a black box about 2" wide, and 5 or 6" long. it's up under the dash by the steering column I think, there is a bundle of wires with a connector that goes into one end. I think there might also be a aluminum heat sink on one side of it. If I remember they are very expensive from GM. I got 2 from a salvage yard and one of them ended up working /forums/images/icons/smile.gif Not a hard repair.
  4. gotmud?
    Feb 23, 2002
    1,172
    up north
    THANK'S
