Where exactly is the "set timing connector" in a 1990?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Jan 17, 2001.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    Where exactly is the \"set timing connector\" in a 1990?
    I need to find the connector for the tan/black single wire that you disconnect when setting the timing. I cant find it. I cant even find the tan wire with black stripe I have an error #42 and I need to find this wire. Thanks.
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Re: Where exactly is the \"set timing connector\" in a 1990?
    I have an '87 and I think they are the same - look on the driver's side firewall area, there should be a wire with a connector, about, oh, maybe 2 inches long. It is kind of below the brake master cylinder on mine, just off the firewall. Good luck, hope this helps.
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I think that is right, I have worked on an '88 and that's what I remember. The emissions sticker under the hood will tell you where to look for the connector.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If I remember right, it's a brown wire with a black stripe. It's pretty much the only wire that is not bundled into the harness. There's a weatherpack connector that you unplug to set the timing.
  5. shum1
    Oct 8, 2000
    270
    UTAH
    Ya, I'm a dumbass I just traced it from the distrib. and it was right there where you guys said. Thanks.
