Where/how did you install your adjustable prop. valve?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Liberator, Mar 23, 2005.
  1. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    It's time to get this adjustable proportioning valve in. I can't seem to locate a place I'm happy with. Well, I have but the hose/fitting size it different than the fittings supplied. Close to the middle of the truck is a nice splice that would be perfect. I would only have to unbolt the female coupler and bolt in the prop valve in the couplers place. Problem is the hose back there is, I think 1/4". The fittings on the prop. valve are the standard size, I think 3/16". I'm not sure! If I knew what size fittings they were my life would be much easier. The brake line fitting that bolts into the rear drums thread into the prop. valve fitting, if that helps. Where did you install your proportioning valve and which adapters did you have to use?
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Have you already done the disc brake swap? I recently did mine using the stock prop. valve an it stops great.:xmas: I do have hydro brakes, don't know if that makes a difference.
  3. Liberator
    Jul 16, 2001
    276
    I have disk brakes and I don't like the rear brakes locking up so easily. I go through rear brake pads more often than front pads.
  4. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    i got new fittings and mounted it to a little bracket i made that was held on by 1 of the 2 nuts that holds the master to the booster. stayed high and dry and was out of harms way.
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I will be on 24Hr duty today, but tomorrow i can snap a picture of where i mounted mine. It is inside the rear pass side of the frame.
  6. Liberator
    Jul 16, 2001
    276
    Pics would be great!
    readymix, did you have a problem with the line sizes or fittings? Did your truck have a coupler where you installed your PV? I was hoping the coupler on mine was the same size as the fittings supplied with my Summitt PV, but the lines on the truck are larger.
    sweetk30, your installation is interesting. There were no adverse effects installing the PV before the factory proportioning valve? I like the idea of having it installed up high. Which line from the master cylinder did you use?
    Both options sound great! They are the original locations I've considered. I'm definitely having trouble finding the right fittings. If anyone else has another location, I'd love to know about it. Going back through the archives I found someone installed one inside the cab!
  7. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    i would suggest selling what you have and pay the extra 40 bucks and get the the new p valbe from www.inlinetube.com
    replaces your stock p valve and adjusts properly.
    i love it
  8. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Thats what I did, works great.
  9. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  10. sweetk30
    Nov 1, 2004
    25,538
    538
    sorry i took off the factory one and put a tee in for the frt and then ran the back threw the adj valve and plumbed it from there to the rear. set it on road test and never needed to reset it again. truck was to tall to need any diff bias for weight in bed.
    frt resivor, small one is line for the rear and back resivor big one is line for the frt.
