Where is #1 ?
Discussion in 'The Garage' started by blazerpunk, Apr 22, 2005.
  1. blazerpunk
    blazerpunk 1/2 ton status
    Feb 3, 2004
    121
    Trinidad, CO
    Well some jack a$$ :blush: (me) must have gotten the wires on the distributer cap one space away from where it should be. Sooo whats the simplest way to figure out which one is #1 on a '90 TBI small block.
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I just went through this last week trying to figure the same thing out. #1 can be anywhere you want it to be as long as you have them in the correct firing order. Remove valve cover and determine when your #1 cylinder is just before TDC, usually 4-10*. Next pull your distributor cap and se where the rotor is pointing and bam you have where #1 should be. That is the way I did mine, got pretty good at finding TDC and removing distributor and all wires.
  3. dschneider
    dschneider Newbie
    Feb 7, 2005
    4
    san antonio
    another way is to remove #1 spark plug (disconnect power wire on distributor so it wont start) and stick your finger over the hole and have someone slowly crank the engine (tap it) when it hits the compression stroke you will fill air coming out the hole, look at the balancer and turn it until the line is at zero, remove distibutor cap and it should be pointing to number 1.
  4. blazerpunk
    Feb 3, 2004
    121
    Trinidad, CO
    Thats just too simple. :tongue1: Can someone slap me now.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Or just look at the timing mark on the balancer.
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    but you have a 50/50 chance of being 180 off.
  7. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    got this?
  8. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Correct
