Where is a good place to run my exhaust?
Discussion in 'The Garage' started by patrickcampbell, Sep 8, 2003.
  1. patrickcampbell
    patrickcampbell Registered Member
    Sep 11, 2002
    60
    I currently have dual pipes running out the rear in frontof the shackles but below the spring. I am planning on getting taller springs and an ORD shackle flip so I need to find a new and safer place to run the exhaust where it is out of the way. ANY PICS OR IDEAS?!?!?!?!
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    i used to have an exhaust system that went all the way to the rear. eventually i found it to be a pita every time i wanted to mess with the suspension... so eventually i just chopped it off right behind the muffler and put a turn down that sorta aims towards the side of the rig, but mainly downward. Works great so far and having it out away from the rear axle and suspension is great.
    j
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    One of my tailpipes hits my rear shackle, I'm just going to make it a little longer. 90s behind the wheels is how I like it.
  4. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Just put the lift on first and then see where you will be able to fit it. Dont do the exhaust before the lift. Also, another thing to keep in mindis if you run the pipes straight out the back, exhaust will come inside the truck while driving with the rear window down. Best bet is to put them out the side, or my choice, on a 45 degree angle pointing between the side and rear.
  5. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    j
    Also watch if your area has inspection turn downs will not pass unless you have a truck. A blazer is considered a wagon and the whole vehicle is a passenger compartment so the exhaust will have to exit either out the sides or rear. Cannot exit under the vehicle.
