Where is my knock sensor (CA truck)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by btolenti, Dec 5, 2003.
  1. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    I cannot find the knock sensor for my ESC. My 86 is a cali emissions L-code 350. I want to replace the knock sensor, because I have been told it can cause engine miss problems at high speed (highway driving, my truck has an intermittent miss).
    I have checked both sides of the block, down by the oil pan, and both sensor locations have plugs in them, not sensors. Would the knock sensor be mounted anywhere else? Do I even have a knock sensor?
    FYI, I have the 7 pin ignition module....
  2. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    The only place that I've seen it would be on the pass. side right beside the starter. I can't imagine where else it could be, but I'll pull my books and see. It may be that it was pulled and plugged and that really IS your problem...
  3. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    according to a wiring diagram I got off this site, California trucks did not have ESC....I am just wondering "why?"
  4. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
  5. dyeager535
    26,979
    That link is taking forever to load, but the way the manuals are written, what that PROBABLY means, is that the next page in that manual covers the CA only ESC system, or, since the ESC system was integral with the CCC system that came on some CA trucks, there would be no seperate wiring diagram for that application. ESC was a "standalone" on non-CCC/EFI trucks, so a seperate wiring diagram in those applications makes sense. With EFI/CCC, I believe ESC is located in the ignition or driveability sections of the wiring manuals.
  6. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    right beside the dipstick!
  7. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    anyone in California have a 86 blazer they could check to see if the knock sensor is on their truck?????
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    On carbed vehicles I have seen them in the rear of the heads. It screws into one of the threaded holes in the head on the back side.
  9. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    I have three sensors toward the front of my intake manifold.
    Two on the water neck and one directly in the intake manifold. One of the ones on the water neck is what looks like a vacuum switch, the other has a single wire coming from it. The one mounted on the intake has a yellow and black wire going to it...
    http://ftw.truckmoxie.com/showownerpic.asp?u=3627&n=350112&pos=1&album=7210
    I also have one high on the drivers side head between the 2 and 4 spark plugs....
    Could one of these be the knock sensor?????
    I am stumped!
  10. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Driver side head is 1 3 5 7 and that sensor is for the water temp gauge.
  11. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    ah! I always get mixed up with Chevys and Fords.... The Ford #1 cylinder is on the passenger front side...
  12. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    I have looked everywhere and cannot find a friggin knock sensor... Could it be because I have an L code 350 and not an M code 350?????
    I go to the Kragen and Napa sites and they have no listing for a knock sensor on a 86 K-5, L or M code! (350 anyways)
    THey do have a listing for the 305 though! Did only the 305's have the knock sensor?
  13. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    I am wondering if the knock sensor equipped motors are the ones with the 5 pin ignition module...
    I have the 7 pin module in my HEI distributor. I think that the MAP might be controlling the timing in my application, since I have one mounted on the firewall, and have no knock sensor... But I am just thinking out loud. /forums/images/graemlins/1zhelp.gif
  14. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    TTT! I really need some input on this? Does anyone know the difference between the 5 and 7 pin modules...
  15. dyeager535
    26,979
    What can I say. The setup you have is MESSED UP. /forums/images/graemlins/smile.gif
    Just looked in my parts manual. It appears your truck should NOT have a knock sensor.
    Can't figure it out, but you have an ECM, a CCC carb (TPS and mix control both) MAP sensor, all the coolant temp sensors, etc., ALL indicative of the CCC system, but it doesn't appear the L code 350 had a knock sensor. It shows on the H code 305, so I doubt it's a mistake in this manual.
    Apparently you have a "Switch, ESC mdl A/trns override (K w/350L, AT,& calif)" which seems to indicate the knock sensor just wasn't used in your setup.
    First I've ever heard of it, but hey, there are LOTS of variations on these trucks.
  16. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    also some EST used a MAP sensor and some didnt, and some also had vacuum advance and others didnt- all with 7 pin plug HEI
  17. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    So could the MAP cause a "miss" during highway cruising? Or should I replace the ignition module first???
