Where is the #1 post on a 90 distributor?
Discussion in 'The Garage' started by BlueOx, Oct 12, 2002.
  1. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    Ok, on the HEI distributor I have on the truck now I know where the # one post is but, I am working on a 90’ distributor with the remote coil and can’t find #1 post. Unlike the HEI distributor the 90’ cap is completely round and I have no idea which post is for the #1 cylinder. Any help would be great.
    Thanks,
    Charles
  2. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    it depenmds on how you drop it in the engine. put #1 at TDC on the compression stroke and drop it in - make a note of where #1 is. it is the relationship with the camshaft that matters not the number or p[osition on the cap...
  3. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    Yes, but where is it on the cap. I know with the HEI its always the one after the tach plug.
  4. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    It is the post that points towards #1. Should be just to the drive side front of center of the manifold. Same basic position as your HEI distrib would be. They will work no matter which post is used for #1, but this is how it comes from the factory.
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    It can pretty much where ever you want it to be as long as you reference it correctly. The vac advance pot should on the left at around 9 o'clock and the # 1 would be at around 3 or 4. That's how mine is anyway. /forums/images/graemlins/confused.gif Good Luck
  6. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    im with jimmyjack home is where you make it /forums/images/graemlins/laugh.gif i dont see why you couldnt put number 1 wherever you wanted...just make the sure the rest follow in correct firing order.
    its a very good possibility that i might be not exactly correct /forums/images/graemlins/smirk.gif
  7. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    I got it working now, thanks for all the help guys.
    Charles
  8. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I know you got it working, so a mute point for you, but others may be interested. As stated it can be any post (as long as the cam, #1 cylinder at TDC compression stroke, and cap line up) and followed by 8,4,3,6,5,7,2 plug wires. I just did the head gaskets on a K5 and the rotor pointed almost directly at the post on the coil when at TDC compression #1 cylinder. The way the cap was put in, it was the 3rd post clockwise from little ridge on the cap (the ridge is on the side where the electrical connectors are on the base of the distributor). This is how it was when I took it out. Again any post can actually be #1 as long as everything is correctly in time. In your conversion did you use the tan with black stripe wire (for electronic advance retard), as I had to disconnect it to correctly time her 89 K5 (per Chilton's manual).
