Where is the A/C Blower Motor?
Discussion in 'The Garage' started by dlaw36, Sep 15, 2005.
  1. dlaw36
    dlaw36 Registered Member
    Jan 11, 2003
    71
    My blower stopped blowing. :mad: The A/C compressor is clicking on and off but no air is coming out the vents. Where is the blower motor located? Under dash or by the dryer? Is this the only thing that I need to troubleshoot or is there a relay of some sort that I need to look at?
  2. uglyangelracing
    uglyangelracing 1/2 ton status
    Jun 6, 2005
    271
    Rhode Island
    Passenger side of the engine compartment. Bolted to the heater box on the firewall.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Passenger side of engine bay , in the black box on firewall , next to the heater hoses . Replacement motors usually require a new blower wheel , as the factory wheel is splined to the motor shaft , and aftermarkets have a d-shaft and nut on the end of the motor shaft .
  4. dyeager535
    26,979
    AC stuff I'm not real familiar with, but there is always going to be a power wire of some sort running to the blower motor. Make sure that has power before swapping the motor. You can also try tapping the motor case when the fan is in the "on" position, sometimes that will get them moving and indicate that it is failing.
  5. dlaw36
    Jan 11, 2003
    71
    Thanks, I will dig into it this evening. :waytogo:
