Where is the best place to buy spider gears...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kwcdawgfan, Apr 24, 2001.
  1. kwcdawgfan
    kwcdawgfan Registered Member
    Jan 13, 2001
    91
    Georgia
    I have a 73k5 fulltime 4x4 and need them for the front end... Fulltime 4x4 w/ a dana 44 (8.5 in 1.31 axle dia 30 spline)...
  2. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    I'd just head down to a local wrecker, any D44 with 30-spline
    axles (which is most every D44 in existence) will have the
    correct spider gears, and should be cheap.
    If you are set on getting new ones, I'd give Randy's Ring &
    Pinion a call. Contact info is:
    Web: www.ring-pinion.com
    Phone: 1-800-292-1031
    Fax: 425-347-1440
    1160 Airport Rd #300
    Everett, WA 98204
    (according to bc4x4.com)
    --Rob
  3. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Summit Racing has a good price on Richmond gears. Or you can look on ebay. They have a ton of gears on there.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Dare I say 4wpw
    Try an independent Dana(Spicer) dealer. Freeway Truck Parts comes to mind.
    Good luck
